Header bolts or studs
Old Jul 11, 2020 | 08:27 AM
Bubba68CS's Avatar
For those running big blocks with headers in A-bodies (specifically 68-72), do you run bolts or studs for your headers? Mostly curious on whether one is easier/harder for installing/removing the headers.
Old Jul 11, 2020 | 08:36 AM
BackInTheGame's Avatar
I run bolts. Due to the limited space available, studs would require more "wiggle room" to R&R the headers.
Old Jul 11, 2020 | 09:10 AM
I typically use bolts but on the set of headers I use with my run stand, it's impossible to get a bolt into one hole due to the bend in the primary tube, so I use a stud there.
Old Jul 11, 2020 | 10:15 AM
green1972's Avatar
ARP Stainless 12 points, and grind down the wrench to 1/3 its size and you can get to the hard to get bolts, my tough one is the drivers rear!
Old Jul 11, 2020 | 07:00 PM
Bubba68CS's Avatar
Thanks guys. Sounds like bolts are the way to go.
oldsw31
May 1, 2016 03:43 AM
74 fastback
Sep 13, 2015 12:58 PM
Stevec
Jan 26, 2014 12:44 PM
j_link
Nov 27, 2011 03:37 PM
johnspd22
Dec 29, 2009 07:36 PM
