Removing 72 455 exhaust studs
Old Apr 13, 2020 | 03:32 PM
garys 68&72's Avatar
I'm working on a 1972 455 jet boat. I have to remove the 40+ year old rusty exhaust manifold studs. I DO NOT want to break any or the heads. Any experienced tips on best practices? TIA.
Old Apr 13, 2020 | 05:54 PM
Heat, and lots of it. My personal favorite technique is to heat the stud/nut/bolt/whatever hot, and then soak it with a good penetrating oil. Do this several times, the idea is to try and get the oil to wick into the threads. After your confident enough oil has made its way into the threads (or your tired of the smell of burnt oil) get the metal glowing red, get a good grip with vise grips, and cross your fingers. If your patient, the bolt will come out. If not, grind the broken bolt flat with the head, drill the exact center of the broken bolt with a small drill, and keep going up in drill size. Do it right, and you will be able to pick out the remaining threads of the broken bolt, leaving the threads in the head relatively intact.
Old Apr 13, 2020 | 06:44 PM
dc2x4drvr's Avatar
Weld a nut onto the stud, heat the head area, then use an impact thread..
Old Apr 14, 2020 | 04:44 PM
Yellowstatue's Avatar
I have heard of using candle wax to wick into the threads after heating.
GHOSTOWLGRID
Oct 8, 2016 01:54 PM
GHOSTOWLGRID
Jun 1, 2016 09:46 AM
Paul Engle
Sep 12, 2015 03:57 PM
QS442
Apr 16, 2014 06:51 PM
ELECMAN
Mar 15, 2010 04:12 AM
