mild cam--detonation
Old Oct 31, 2020 | 04:41 PM
ben442's Avatar
Could a mild cam shaft (218/224) in a higher compression (10.5-1) engine cause detonation?
Old Oct 31, 2020 | 05:34 PM
cutlassefi's Avatar
Yes. But it can also squeeze by, depending on the tune, gear etc.
Old Oct 31, 2020 | 07:47 PM
When is the detonation occurring? It may be attributed to your timing settings, lean fuel feed, etc.
Old Oct 31, 2020 | 08:24 PM
ben442's Avatar
I've actually solved the problem of pinging with a timing adjustment and the addition of octane booster this past year, but was wondering if cam duration was a factor
Old Oct 31, 2020 | 08:50 PM
Yes, cam duration and valve opening / closing pointes are factors as they determine the cylinder pressure on the compression stroke (dynamic compression).
chris83
Jul 25, 2019 04:44 PM
boese1978
Aug 7, 2012 06:57 PM
nonhog
Jul 30, 2012 03:18 PM
1973olds98
Oct 26, 2010 08:50 AM
Wireman134
Aug 22, 2008 08:28 PM
