Best deadhead mechanical Olds fuel pump
And I'm not talking about Grateful.
What would be the best deadhead mechanical fuel pump to put on a mildly warmed over 455? Before I pull the trigger on doing an in tank electric with new tank, I want to use the original tank and lines. Since there is no return line, I need a good flowing deadhead mechanical unit to install until such time that I do the tank, electric fuel pump and lines.
Was there an actual deadhead application used on a 455?
I'll just go with this Spectra Premium from RockAuto SP1033MP. It is listed as having a free flow rate of 60gph. Should be plenty for the engine in question.
https://www.rockauto.com/en/moreinfo...956670&jsn=258
