Weird place for an oil leak
Old Jan 20, 2019 | 07:02 PM
danktx's Avatar
I'm putting together a 455 and I thought I was about ready to install my engine. I made me a pre-oiler out of an old HEI and started pumping oil through the motor and I have a leak. Oil is coming out the rear holes in the front stiffening plates that are spot welded to the pan for the 2 front 5/16 corner bolts. I've ordered a new pan gasket but I was hoping someone here could clue me in on what I missed during assembly. It just seemed strange that it would leak from both sides at that location.
DK
Old Jan 20, 2019 | 07:51 PM
don71's Avatar
same but different
It shouldn't leak. But stuff happens. If you have to do this again, use the diesel oil pan gasket. Part # OS30471C. It has a metal inner surrounded by...gasket material. Not cork. Most Olds guys consider this one a better gasket for the modern Olds V8 engines, big or small 1964+ and up.
Old Jan 21, 2019 | 02:15 PM
shiftbyear's Avatar
Don71, is that part # a GM or Fel-pro? Thanks for posting.
Old Jan 21, 2019 | 03:07 PM
As per Don's suggestion:
https://www.rockauto.com/en/moreinfo.php?pk=125928&cc=1435198&jsn=1
I just recently installed this gasket. Worked like a charm. FEL-PRO OS30471C
A Hodge-bodge of misinformation on the Internet. One site says this, another says that, some say nothing at all. Some even say cork when in fact, the seal is not cork but neoprene, instead. Even RA has this gasket description listed incorrectly. There is no cork in this gasket.
This is the one I ordered from RA and the one I received from RA. The side pieces are black neoprene rubber with a full metal interior. Rubber end-pieces are identical to all other types.
Old Jan 21, 2019 | 04:43 PM
danktx's Avatar
thanks for the info. I'll let y'all know if its anything interesting. Thanks for the suggestion.
DK
Old Jan 21, 2019 | 05:19 PM
classicmuscle442's Avatar
Did you use a dab of silicone in the corners?
Old Jan 22, 2019 | 06:32 AM
danktx's Avatar
Yes, I used silicone at the corners. I've replaced the oil pan on the engine currently in the car and never experienced this before. Its the leak under oil pressure out of those two holes that has me stumped.
DK
tommieb
Feb 19, 2021 01:22 PM
twintracks
Jul 5, 2014 05:51 AM
JCMC64
Sep 4, 2012 11:58 PM
Lady72nRob71
Apr 1, 2011 05:13 AM
polcatt
Nov 19, 2006 01:33 PM
