oil pump drive shaft
Old Jan 13, 2019 | 06:17 PM
deadeyejedi's Avatar
i hate to even admit this but ,as ive been getting back to my 455 build I realized i never installed the oil pump drive shaft I found it going through a box of parts .The oil pump and pan is installed now and i was hoping not to tear it apart to install it .How critical is it to remove the retainer washer on the shaft and drop it in from the top? If its any issue at all i will bite the bullet and redo it. This what i get for stopping and going so many times on this motor my memory has alot to be desired.as always thanks
Old Jan 13, 2019 | 06:39 PM
BillK's Avatar
The only time it will become a problem is if you pull the distributor and the shaft comes along with it and falls down in the wrong place. I am not sure this can even happen in an Olds but I know it can in most Ford engines. If you aren't worried about that part then it wont hurt anything.
But ..... for the price of an oil pan gasket and an hour of your time, I would probably go ahead and fix it right
Old Jan 13, 2019 | 06:49 PM
don71's Avatar
same but different
My retainer washer has been gone a long time. It hasn't been a problem when pulling the distributor.
Old Jan 14, 2019 | 05:42 AM
Lonnies Performance's Avatar
Had that happen to me on a Mustang one time... pulled the distributor up & heard a clank as the shaft fell into the oil pan.
Took a few hours to get it back.
Maybe put a small amount of Permatex on the part that goes into the pump so it does not easily pull out in the future.
Old Jan 14, 2019 | 06:39 AM
The driveshaft nearly always gets stuck in the distributor at some point, which means that you have to forcibly pull the distributor out, sliding the retainer down the shaft until the retainer drops into the oil pan. The only reason why that retainer is even on the shaft is so that on the engine assembly line, they could drop the shaft into the block while it was rolled over, before the distributor was installed. Otherwise, it would just fall out. Most of my motors don't have the retainer.
Old Jan 15, 2019 | 04:49 PM
thank you guys for the replies
92banana
Dec 30, 2017 10:52 AM
JRubino
Mar 8, 2014 05:33 AM
EightyEightCut
Jan 19, 2014 08:35 PM
grand73am
Jul 4, 2013 06:32 AM
greenslade
Feb 1, 2010 01:52 PM
