Mechanical Fuel pump question
Old Oct 12, 2018 | 03:19 PM
Big Dawg's Avatar
Hey guys,
I just have a quick question regarding the mechanical fuel pump. If it is completely removed off the block should I be aware of anything?
I went to a FITECH EFI setup and removed the mechanical pump as it no longer has any use. But I am worried that something may leak out once the motor is started as there is a hole where the pump lever was inserted into. Should I just cover it up with a small piece of sheet metal and some pentax gasket maker?
thanks
Old Oct 12, 2018 | 03:34 PM
Dave26's Avatar
Summit Racing
Old Oct 12, 2018 | 03:57 PM
That hole leads directly into the crankcase, so yes you need to block it off in order to keep oil inside the engine and dirt, water, etc. out of the engine.
Old Oct 12, 2018 | 04:13 PM
Big Dawg's Avatar
Awesome thanks guys.....had no idea that there was a plate available.
will order asap
Old Oct 12, 2018 | 07:35 PM
Gerald Nickels's Avatar
Or make one real easy.
Old Oct 12, 2018 | 07:52 PM
Big Dawg's Avatar
I decided to make it myself..just copied out the template from the base of fuel pump. I had a piece of 1/4 gauge metal.
thanks for the help guys.
Gone Johnson
May 18, 2020 07:22 PM
kuseetha
Aug 9, 2018 05:21 AM
BlueCalais79
Nov 6, 2014 10:59 AM
BenJammin
Oct 9, 2013 09:41 AM
HWYSTR455
Jun 27, 2013 04:48 AM
