Mechanical Fuel pump question
Hey guys,
I just have a quick question regarding the mechanical fuel pump. If it is completely removed off the block should I be aware of anything?
I went to a FITECH EFI setup and removed the mechanical pump as it no longer has any use. But I am worried that something may leak out once the motor is started as there is a hole where the pump lever was inserted into. Should I just cover it up with a small piece of sheet metal and some pentax gasket maker?
thanks
thanks
