cam selection
Old Apr 4, 2019 | 08:09 AM
oldaman's Avatar
cam selection
seeking cam advice . 69 cutlass 455 4spd 373 axle . p.s p.b a/c . 455 060 over small valve c heads . performer intake . headers .hei ignition running stock valve train. how big of a cam can i use and if i switch to adjustable rocker arms would it expand my choices pistons are silvolite 1630 all help appreciated .
Old Apr 4, 2019 | 12:00 PM
@cutlassefi is the go-to source for camshaft info (among other things) on here. I could give you an opinion but his would be the last word, so let's see if he chimes in.
Old Apr 4, 2019 | 05:20 PM
cutlassefi's Avatar
Anyone familiar with that Silvolite piston? Compression ratio?
Old Apr 4, 2019 | 08:27 PM
Here's what I found in a web search:
https://uempistons.com/i-17647-singl...8-1968-76.html
Silvolite Piston - 7.5L GM (V8) 1968-76
ALLOY: 332
3.031" dia. head recess .320" deep.
Comp. Ht. IN: 1.720
COMPRESSION RATIO: 8.4
The dish volume calculates to 37.8 cc but the piston is a bit shorter than factory spec.
Old Apr 4, 2019 | 08:38 PM
svnt442's Avatar
https://uempistons.com/i-17646-singl...8-1968-76.html
1630ALLOY:332BORE INCH:4.125BORE MM:104.8COMP. HT. IN:1.720COMPRESSION RATIO:8.4CROWN CC:+37.5ccCROWN TYPE:DISHCYLINDERS:V8ENG. DISP LITERS:7.5ENG. DISP. IN.:455ENGINE FAMILY:Oldsmobile V-8INTERCHANGE:FM 344PMFG:OldsmobileO.E. ASSEMBLY:400571, 231110OVERSIZES:STD .020 .030 .040 .060PIN CONFIG.:OffsetPIN DIA IN:.980PIN DIA MM:24.9RING SIZES:2-5/64, 1-3/16TOP LAND:.245
Brgrenier
Aug 31, 2025 02:48 PM
ajmanning84
Jun 23, 2024 04:34 PM
dopgx3
Jun 8, 2017 07:55 AM
scooter123
Mar 29, 2013 08:09 AM
jag1886
Sep 10, 2011 01:26 PM
