10w30 or 20w50?
Old Mar 24, 2019 | 01:46 PM
72455's Avatar
1972 U code Supreme
10w30 or 20w50?
The factory specs for oil in my 72 U code Cutlass Supreme is 10w30. It has a W30 cam and .030 over bore and just rolled over 101K original miles. With the mods done to the engine, should I stick with factory specs or switch to 20w50? At highway speeds, I get around 50 psi oil pressure, so I was just wondering...
Thanks,
Dave
Old Mar 24, 2019 | 01:49 PM
coppercutlass's Avatar
Chevy budget Olds powered
sounds like its still healthy. the 10w30 would be my choice,
Old Mar 24, 2019 | 02:10 PM
X2 - 10w30
Old Mar 24, 2019 | 03:25 PM
Dave - 10w30. Are you thinking of using synthetic? BTW your oil pressure sounds healthy.
Old Mar 24, 2019 | 05:25 PM
72455's Avatar
1972 U code Supreme
Nope...I use Valvoline VR 1 conventional.
Old Mar 24, 2019 | 05:45 PM
Nice. That stuff isn't readily available up here. I'd have to use a different product like Lucas for Classic cars. Runs about $55 for 5 quarts up here. I hope you're not using a Fram oil filter. They're the cheapest least protective filter on the market.
Old Mar 24, 2019 | 07:29 PM
72455's Avatar
1972 U code Supreme
No sir ..Napa Gold😀
Old Mar 25, 2019 | 05:39 AM
Ozzie's Avatar
Thanks,
Dave
You're probably O.K. where you are. Oldsmobile said that 20W-50 could be used down to +20F, and 10W-30 could be used down to +10F. The high temperatures and wear on the engine probably should also be factors. 5W and 5W-20 oils were not recommended for sustained high speed driving. If the viscosity increasing additives don't work you'll have the lower number. The VR1 & NAPA Gold seem like good choices. I've been using the 20W-50 or 15W-50 mostly because of the high temperatures encountered. I-10 gets hot in the summer, and it doesn't freeze here much any more.
May 6, 2026 07:30 PM
drjr56
Sep 13, 2016 06:25 AM
Railguy
Jan 17, 2016 02:28 PM
Thomas Simcich
Oct 13, 2010 11:28 AM
airhead6969
Aug 10, 2006 11:00 AM
