Stock cam timing question
Old Sep 19, 2018 | 06:43 PM
danktx's Avatar
I'm looking at the cam specs in the 1967 service manual. The intake shows to begin opening at 21*. My Comp cam shows intake opening 25* at .006.
Is the stock cam measured like the Comp cam or maybe from .000?
Old Sep 19, 2018 | 06:54 PM
What engine?
Old Sep 20, 2018 | 04:33 AM
cutlassefi's Avatar
What engine?
Really doesn’t matter, all the stock stuff WAS measured from 0.
Most all today measure from .006 like Comp, but there are a few that don’t. Crane and Edelbrock for instance measure from .004. Engle/Mondello measure from .008. Hope this helps.
Old Sep 20, 2018 | 06:53 AM
Which is exactly why the factory timing numbers are suspect. It's extremely difficult to measure first motion of the lifter on a cam lobe. Also keep in mind that it isn't just duration and max lift that matters. It's the area under the curve that determines total airflow. The classic example of this is the NHRA stock class "cheater cam". Same duration and lift as OEM, but much more aggressive ramps on the lobes.
Old Sep 20, 2018 | 07:27 AM
danktx's Avatar
It does.
I'm putting together a 455 with a Comp XE262H cam and I was trying to determine the delta for lift and duration between a stock cam 330 or 400 4B w/AT and the Comp cam.
Thanks for the info.
1of1442
Nov 13, 2019 12:26 PM
george landis
Mar 23, 2017 03:17 PM
scooter123
Mar 9, 2013 11:30 AM
AZ455
Aug 30, 2012 05:52 PM
WoofWagon
Apr 30, 2012 01:08 PM
