What's needed to switch to hydraulic roller cam
Old Sep 20, 2018 | 10:17 AM
chris83's Avatar
I have a 461 with big valve c heads right now I'm running comp cams extreme energy 284 flat tappet cam but alot of people are telling me to switch to a hydraulic roller cam setup.so didnt know what was all involved is switching to roller.
Old Sep 20, 2018 | 11:21 AM
My442's Avatar
Cam, lifters, pushrods, springs, thrust bearing at a minimum.
Possibly the distributor gear as well.
Rocker arms if you are using stock ones, and guide plates for the pushrods.
And at least $1,000.
Old Sep 20, 2018 | 11:31 AM
chris83's Avatar
I'm using the comp cams full roller rockers with the extreme energy 284 cam as a whole kit pretty big springs,my cam is 541/542 lift so I'm thinking around same or maybe just a touch bigger.
Old Sep 20, 2018 | 05:01 PM
cutlassefi's Avatar
It’s not the size of the spring, it’s the pressure. A roller requires about 150 on the seat and 375-390 open. Normally that’s too much for a flat tappet.
And I wish people weren’t so enammered by lift. That’s only part of the equation, especially with stock heads.
Vega
Jul 25, 2023 02:32 AM
cwb442
Dec 25, 2016 05:28 PM
CanadianCutlass
Dec 23, 2015 02:36 PM
CLcutlass
Aug 16, 2011 06:43 PM
72RocketPower
Aug 11, 2005 04:51 AM
