1968 H/O Temperature Sending Unit Location
Old Nov 25, 2018 | 07:36 AM
geardoc66's Avatar
I am working on a 1968 H/O with air conditioning. Can someone confirm the correct location for the temperature sending unit and the thermal vacuum switch on the intake manifold?. I tried looking at all of the cars with the hood open at MCACN last weekend and to my dismay, there was a mix of both ways. Having the sender on the driver side makes the harness for the sender less of a stretch and seems more correct. I have a '69 service manual and assembly manual and in both, the temperature sending unit is in the driver side and the TVS is on the passenge side. They are currently the opposite in the '68 and I have no service or assembly information to confirm if it was indeed different in '68.
Old Nov 25, 2018 | 11:53 AM
DocRocket68's Avatar
Geardoc66,
Per the 1968 P.I.M. (assembly manual) all V8 engines including 442's and H/O's had the temperature sending unit on the
passenger side of the intake. The thermostatic vacuum switch, if used, would be on the drivers side. This changed in 1969.
Yes the wiring harness is a bit stretched to reach it.
Brian
Old Nov 25, 2018 | 06:19 PM
83hurstguy's Avatar
Passenger side is correct for all '68s, as Brian noted above.
Old Nov 27, 2018 | 05:21 PM
geardoc66's Avatar
Thanks guys, much appreciated!
onofre442
Jul 22, 2015 07:51 PM
oxford
Mar 19, 2013 05:18 AM
pcard
Feb 22, 2013 03:08 PM
Stevec
Sep 13, 2010 07:48 AM
Kace
May 17, 2010 05:37 AM
