Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Temp sending unit/switch
Old Mar 18, 2013 | 11:19 AM
oxford's Avatar
Need help in locating a temp sending switch for 62 Starfire with idiot lights in inst. pnl. Any one know where to obtain? Thread on this forum indicates a Borg Warner # D363AF. Any help appreciated.
God Bless the USA and Veterans
Old Mar 18, 2013 | 04:39 PM
navvet's Avatar
I purchased a temp sending unit from USA auto parts for my 64 88. If it is the sending unit they have it...a 'switch' I don 't know!!!
Old Mar 18, 2013 | 05:32 PM
oxford's Avatar
Checked with them, the only one they have is for a F85 and only has one terminal. Thank you for the answer. Still looking everyone
Old Mar 18, 2013 | 05:54 PM
jaunty75's Avatar
I see the terms used interchangeably, but I agree, to my mind, it's a "sending unit," not a "switch."
Old Mar 18, 2013 | 06:56 PM
Oxford, when you say "lights," I assume you mean a HOT and a COLD light (I've never owned a '62). If that's the case, there are a lot of options that should work, even if not exactly "correct."
My '68s both had HOT / COLD lights, and used a Standard Automotive Products TS15 (if my memory serves me).
This sender is listed for buicks back to 1960, but for Olds only to '65.
If it uses a different thread, you could always adapt it, but I'd bet it would serve your needs.
Old Mar 19, 2013 | 05:18 AM
rocketraider's Avatar
Oldsdruid
62 had round "posts" on the temp indicator switch rather than blade terminals as on the switch above. You can change the plug and the above will work fine. However, I think you'll be able to find the correct piece.
This one is technically a switch since it only turns an indicator lamp on or off. A sending unit implies variable output as with a gauge. But that's splitting hairs.
costpenn
Nov 7, 2013 09:29 AM
pcard
Feb 22, 2013 03:08 PM
54oldz
Jun 20, 2012 07:13 PM
silverriff
Oct 7, 2008 07:26 AM
