ka heads
Old Dec 21, 2018 | 10:07 AM
oldaman's Avatar
ka heads
i have a choice of using big valve ka or big valve c heads any difference between them. going on a 030 455 mild build. all info appreciated
Old Dec 21, 2018 | 11:13 AM
442Harv's Avatar
As far as flow, they are about the same. If the K are 71 or newer, they will probably have harden seats,compared to the C.
Old Dec 21, 2018 | 11:21 AM
K and KA heads are 1973-up, primarily for marine applications. Keep in mind that the seats are only induction hardened to a minor depth. Cutting the seats will pretty much remove the hardened layer.
Old Dec 21, 2018 | 03:42 PM
11971four4two's Avatar
MOTORHEAD
rate the heads
pull off all the rocker arms
Lay your straight edge across the top of the valve stem
Any above or below is not ideal
Cheap leak down test
Put head in parts washer tank fill port with fluid
Tap the vave stem with a hammer "lightly"
Observe any leaky around valve face / head interface
I guess pick which pair will need less machining would be my choice these days
All The Best
Old Dec 23, 2018 | 10:38 AM
VinMichael's Avatar
The KAs might have a deeper spring pocket than the Cs. If so that’s a factor for valve spring choice.
Old Dec 24, 2018 | 03:07 AM
oldaman's Avatar
ka heads
thanks to all who replied good info and ideas
max66bhs
Nov 30, 2018 04:09 AM
Chuxter
Nov 6, 2015 10:02 AM
LMC
Mar 17, 2015 05:01 PM
Danp76
Mar 19, 2013 06:14 PM
MN71W30
Jan 7, 2011 10:36 AM
