C or G heads
Old Nov 5, 2015 | 06:18 PM
Chuxter's Avatar
1970 Cutlass Supreme
C or G heads
I have a set of C and G heads, they will both need rebuilt. The C heads look to be in a little worse shape. Is there much difference between the 2 sets.
Old Nov 6, 2015 | 02:05 AM
madmax442's Avatar
Cs are supposed to flow better but I doubt it's anything huge! I'd use the Gs if they are in better shape.
Old Nov 6, 2015 | 06:59 AM
The difference is negligible. Use the ones with big valves. The G heads DO have induction-hardened valve seats from the factory, however. Of course, this is a very thin layer and most of it gets removed if the valve seats are cut anyway.
Old Nov 6, 2015 | 08:27 AM
madmax442's Avatar
Like Joe said, use the bigger valve heads! Just beware C heads came in big and small valve sizes! I've read that some have flowed B valve heads and got better numbers! I really think it's a crap shoot if they are untouched except for the J=Junk heads!
Old Nov 6, 2015 | 08:55 AM
All BBO heads except the J heads came in both big and small valve sizes. All except Js have about the same flow numbers. Differences that you see in published tests are based on flowing one or two heads and do not represent a statistically valid sample size. Manufacturing tolerances and core shift will account for significant changes from one "identical" unported head to another.
Old Nov 6, 2015 | 09:52 AM
madmax442's Avatar
Thanks for clearing that up Joe! I guess I wasn't aware that all BBO heads except the Js came in big and small valves! I thought some like the Ds were only big valve!
Old Nov 6, 2015 | 10:02 AM
Actually, you are correct. Sorry for the brain fart. I was referring to the common BBO heads. The D, F, and H heads only came with big valves. All A, B, C, E, G, and K heads could be had either way.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
