Engine mount height
Old Mar 25, 2019 | 07:13 AM
ajr2820's Avatar
Engine mount height
I am swapping the 350 with a 455. I am using the mounts for the 350 since I already had the brackets. I understand this will work, however, does this cause any height differences with this set up vs. swapping over to BB mounts and brackets? The reason I ask is that I am running a Torker intake and want to be able to gain as much hood clearance as possible.
Old Mar 25, 2019 | 07:17 AM
TripDeuces's Avatar
Engine mount attachment points are at the same height and place on both engine blocks but the 455 is approximately 1.5 inches larger in height and width.
Old Mar 25, 2019 | 07:20 AM
don71's Avatar
same but different
You will have plenty of hood clearance with a Torker in 72 cutlass.
You are correct in using the sb mounts and brackets on your 455. The engine will be exactly where it should be and everything will be right. The only major thing that is changing is the deck height of the engine.
Old Mar 25, 2019 | 07:21 AM
I'll ad that the crank centerline is in the same mounted position in both engines. This is a good read.
https://classicoldsmobile.com/forums...tion-list.html
Old Mar 25, 2019 | 07:34 AM
Wow!
My work here is done.
Old Mar 25, 2019 | 07:35 AM
ajr2820's Avatar
Good to know. Thanks. Given that it will keep the crank centerline in the same location, I wonder why they had 2 mounting systems to begin with?
Old Mar 25, 2019 | 07:44 AM
In most years there WEREN'T two different mounts. This was ONLY in model years 1969-1972 and ONLY in the Cutlass line, yet it has spawned about a bazillion threads.
GM went though a massive and costly recall for broken motor mounts across most car lines in the late 1960s. Because of this, Olds (and other divisions) phased in new motor mounts with an interlocking design. Olds originally used this design only on the high torque BBO motors, but by 1973 it had spread to all mounts. FYI, the new early style mounts (Anchor 2261) now incorporate the interlocking feature as well, so the need for two different designs has been overcome by events.
I'll also take this opportunity to again suggest that we stop calling them "350" and "455" mounts. Through the 1968 model year, the first design mounts (with the 2261 rubber mounts) were used with EVERY Olds block in an A-body, from 330s through the 455 in the 1968 H/O. The second design mounts (the stronger ones with the 2328 rubber mounts) were similarly used with EVERY Olds block from 1973-up, including the 260, 307, and 455. It was only model years 1969-1972 where the two designs were used in the same year.
Old Mar 25, 2019 | 08:33 AM
Wow!
In case you didn't notice my post was a previous recording of one of yours.
Old Mar 25, 2019 | 08:35 AM
I did and I'm OK with that. Imitation is the sincerest form of flattery.
Old Mar 25, 2019 | 08:56 AM
ajr2820's Avatar
Makes sense now. Wasn't aware of the issues with the old mounts breaking.
Old Mar 25, 2019 | 09:14 AM
The original 1960s vintage mounts were simply metal end plates with rubber molded in between. The driver side is in tension, so when the rubber ages, engine torque causes it to separate. Couple this with the solid rod style throttle linkage used in the 1960s, and that's a recipe for disaster. This is also why Olds went to a cable throttle linkage in 1968. The cable is much less likely to jam the throttle open if the motor mount separates.
oldsman61
Apr 12, 2017 07:26 AM
ah64pilot
Apr 26, 2011 09:22 PM
jo75olds
Apr 25, 2011 07:51 AM
bullet1
Aug 12, 2009 09:41 PM
Oldsprepp
May 16, 2008 06:37 AM
