Valve Cover Question
Old Mar 2, 2019 | 07:23 AM
ajr2820's Avatar
I am replacing the SB in my 72 Supreme wit a 455. Was there a difference in the valve covers between the SB and BB engines? The 455 had aftermarket covers that I won't be using and I would like to put the ones off the 350 and use those temporarily until I can get budgeted for a nice Offy set. It is an AC car as well. Will the SB covers fit or will they hit anything?
Old Mar 2, 2019 | 07:29 AM
tru-blue 442's Avatar
Old School Olds
Only diff is the v/c's on the 455 in a Cutlass would be the notched style for the a/c on one side and the brake booster on the other.
Other than that they will bolt right on.
Old Mar 2, 2019 | 07:41 AM
RetroRanger's Avatar
72 Olds CS
Some people have modified their AC box and gone to a different smaller size booster in order to accomadate aftermarket or taller valve covers, in a A body. I sourced some notched VCs like Adams pic shows. The SBO VCs are the same without the notch, they might fit but it's pretty tight w the notched ones so IDK if you will be able to remove the VCs easily w the engine installed
Old Mar 2, 2019 | 02:23 PM
svnt442's Avatar
See...I swapped a 455 into a 1970 Cutlass S about 25 years ago that was an A/C car with power brakes. I used the valve covers from a 350 and I didn't modify a thing. It never hit the A/C box or the brake booster. The 455 that was in my 442 was also wearing standard valve covers when I got it (back) and there were no clearance issues. So I'm not really sure why any modifications would be needed to use standard valve covers. Are they tight? Sure. Do they make contact? Not that I have seen.
Old Mar 2, 2019 | 05:36 PM
shiftbyear's Avatar
Did all 445's come with the notched valve covers or just the ones with power brakes or air conditioning? Thanks
Old Mar 2, 2019 | 06:19 PM
72 Olds CS
Randy can you remove the unnotched covers in an A body w AC and power brakes w the engine in the car?
i think all 455 equipped A bodies came w notched valve covers
Old Mar 3, 2019 | 05:40 AM
ajr2820's Avatar
Thanks. Exactly the info I was looking for.
Propaneking
Mar 24, 2017 07:21 PM
johnnyjaws
Oct 23, 2015 01:12 PM
72cuttys
Mar 28, 2014 11:03 AM
Al Graaf
Dec 30, 2011 09:29 PM
Eddie Hansen
Apr 10, 2010 10:12 PM
