Which carb mounting gasket?
Old Jan 12, 2025 | 07:22 AM
Warren Seale's Avatar
I need to get a carb gasket for my W30 engine. There appears to be two types: a single secondary opening and a pair of secondary openings. Which one should I get? The engine assembly manual shows the 60335 type. Does it really make a difference?
Amazon.com: FEL-PRO 60334 Carburetor Mounting Gasket : Automotive Amazon.com: FEL-PRO 60334 Carburetor Mounting Gasket : Automotive
Amazon.com: FEL-PRO 60335 Carburetor Mounting Gasket : Automotive Amazon.com: FEL-PRO 60335 Carburetor Mounting Gasket : Automotive
Old Jan 12, 2025 | 08:24 AM
I've seen similar styles/differences on other carb. base mounting gaskets. I've actually seen them provided in rebuild "kits". Honestly, I don't know the exact purpose. I read (via Cliff Ruggles) the base gasket with a single secondary opening also has those two small U channel slits to accommodate some type of weak ported vacuum used primarily for EGR functionality. Which is correct, I don't know. I suspect, but can't confirm they're both of the same thickness? Again, don't know. If the assembly manual demonstrates 60335 that would be my choice.
Old Jan 12, 2025 | 01:26 PM
The original gasket was P/N 408597. Unfortunately today the replacement parts manufacturers have consolidated part numbers, but the consensus is that it's the gasket with the notches in the primary bores.
mb13
Mar 15, 2024 05:52 PM
pappy
Sep 21, 2018 03:59 PM
Oldssupreme
Sep 1, 2018 06:02 AM
fatgroundhog
Jun 14, 2015 03:04 PM
spyke
Mar 28, 2013 08:13 PM
