Correct engine color 1969 442
Old Mar 21, 2025 | 08:56 AM
442b's Avatar
Time to reseal oil leaks. I'm preparing to pull the motor out of my 1969 Oldsmobile 442. It is numbers matching and has a 400 engine which I'm not sure if it's the correct color or not. The previous owner didn't have much history on the car other than it is mostly original and numbers matching. The engine, as you can see is painted gold which I researched & found 350's were gold and 400's were bronze. There's nothing wrong with the current paint other than it may be wrong. I guess the question here would be, were all 1969 442 400 engine blocks painted Bronze? Any help would be appreciated.
Old Mar 21, 2025 | 10:28 AM
acavagnaro's Avatar
I can tell you with absolute certainty that gold color is wrong. Depending on how much coverage there is on the engine, it would imply the engine's been out before and someone thought it best to paint over the bronze. The correct '69 442 engine color is bronze. Nothing else. Have you confirmed it's numbers matching?. That gold paint would concern me in that regard. At least it's a 400G.
Old Mar 21, 2025 | 11:02 AM
It appears to have a little more red in it than standard SBO Gold, but is not as dark as engines I've seen in the correct Bronze. I'm pretty sure I recall you saying that the engine is the numbers-matching original, so no worries there.
Contact these guys: https://www.hirschauto.com
I happen to know they have some correct Bronze engine enamel in stock.
Old Mar 21, 2025 | 11:46 AM
442b's Avatar
Thanks for the replies so far. Hoping to hear from a few more on this. Transmission coming out this weekend for rebuild. Motor will be April. Yes, it is numbers matching. I have pictures of the serial numbers on the engine & transmission. I purchased 3 cans of the correct Bronze from Fusick Automotive in CT. Reasonably priced. I just want to be 100% sure that the current color is wrong so I can correct it while the motor is out of the car.
Old Mar 21, 2025 | 11:59 AM
Sugar Bear's Avatar
Gold is definitely not the correct engine color, it should be bronze. With the engine being original, you may find some of the original color without much trouble on the sides of the oil pan. Most folks doing a freshen up color change won't paint that area unless the engine was out of the car.
Old Mar 21, 2025 | 01:28 PM
allyolds68's Avatar
Fusick Bronze
Old Mar 21, 2025 | 01:41 PM
Tri-Carb's Avatar
Thorton's version of the same paint for 69 Olds 400 G engines:
THORNTON GM APPROVED BRONZE ENGINE PAINT OLDSMOBILE CUTLASS 442 H/O | eBay
Old Mar 21, 2025 | 04:42 PM
442b's Avatar
Fusick Bronze
Are you happy with it? Is it accurate? And what color did you paint over?
Old Mar 21, 2025 | 04:53 PM
allyolds68's Avatar
I’m happy with the color.
There are a few different shades that I’ve seen. I originally painted the engine using paint from Tamraz. It was much lighter, almost a tan color. That color seems to be used on earlier 65 or 66 engines.
I had an original 69 G block for a while that I was saving in case I ever wanted to replace the 455 that I have now. It had original paint on it and it was very close to the Fusick paint I used.
Old Mar 21, 2025 | 05:30 PM
tiogatwister's Avatar
So I have found that this is the closest to the original color for the 68/69 400 engine.
TRUSTED QUALITY SINGE
RUST-OLEUM
HIGH HEAT ULTRA
LONG LASTING FINISH
STOPS
SEMI-GLOSS AGETI COPPER
Old Mar 21, 2025 | 05:44 PM
I give the credit to 442bro, he is the one that told me about it.
http://442bro.com/
Old Mar 21, 2025 | 05:53 PM
allyolds68's Avatar
RUST-OLEUM
HIGH HEAT ULTRA
LONG LASTING FINISH
STOPS
I test painted it on the 69 block that I had and it wasn’t even close.
Old Mar 21, 2025 | 06:06 PM
I used the Fusic bronze and it was way to red in my opinion, this is the Rustoleum aged copper, to each there own but I feel this is closestvto factory color.
Old Mar 21, 2025 | 09:15 PM
Cfos0031!'s Avatar
This formula (mixed) was used after scans of the original paint that was on the engine. I think must of us are close to the orignal color but not 100% correct.
Old Mar 21, 2025 | 10:47 PM
FStanley's Avatar
the fact of the matter is that I think engine color paint batches were not as closely made as body paint colors. They didn't worry or care as much. also over time the original paint probably faded with use and heat, etc etc So the reference bronze people are trying to match may not be that consistent.
Old Mar 22, 2025 | 04:45 AM
442b's Avatar
That came out very nice. If mine looks as good, I will be very happy. I just want the engine to be correct or close to it since it's going to be out, may as well get it right. Thanks for your post. BTW, what year is your car and is that your car on your avatar?
Old Mar 22, 2025 | 09:08 AM
OLDSter Ralph's Avatar
Originally Posted by fstanley
the fact of the matter is that i think engine color paint batches were not as closely made as body paint colors. They didn't worry or care as much. Also over time the original paint probably faded with use and heat, etc etc so the reference bronze people are trying to match may not be that consistent.
x 2
Old Mar 22, 2025 | 12:16 PM
442b's Avatar
Here's one of the pictures I took while my car was on the lift at the muffler shop a few months ago, forgot I had it. But, I believe it clearly shows the original color on the harmonic balancer that a previous owner missed when they painted the motor gold. Thoughts? Transmission out today & going to the shop on Monday, motor coming out over the next two weeks.
Old Mar 22, 2025 | 02:17 PM
^^^ That sure looks like SBO Gold to me. Left from previous (incorrect) re-paint?
Old Mar 22, 2025 | 02:37 PM
442b's Avatar
"That sure looks like SBO Gold to me"??? Looks like Bronze to me, or am I not seeing something.
Old Mar 22, 2025 | 02:49 PM
"That sure looks like SBO Gold to me"??? Looks like Bronze to me, or am I not seeing something?
Are we not talking about the worn surface on the balancer? It looks gold to me.
Old Mar 22, 2025 | 05:33 PM
442b's Avatar
Yes, most comments have said the engine looks 350 Gold. So, if the engine is Gold, the Balancer looks Bronze to me. I don't know to be honest. Hope others chime in opinions. Thanks
Old Mar 22, 2025 | 06:05 PM
66-3X2 442's Avatar
How does this color look?
Old Mar 22, 2025 | 06:36 PM
I like it, and I bet I know where it came from.
Old Mar 22, 2025 | 06:38 PM
Cfos0031!'s Avatar
Yes, that is my car this engine is in. 1969 442
Old Mar 22, 2025 | 06:51 PM
66-3X2 442's Avatar
You have the pattern.
Old Mar 23, 2025 | 04:49 PM
maddoctor's Avatar
[QUOTE=442b;1621551]That came out very nice. If mine looks as good, I will be very happy. I just want the engine to be correct or close to it since it's going to be out, may as well get it right. Thanks for your post. BTW, what year is your car and is that your car on your avatar?
I have seen a few different variations, I went with the Fusick paint. It is in between the red bronze and the 350 gold. It may not ne exact but as one learned member noted there was not much attention given to engine paint as to body colour. I am sure every assembly plant had a slightly different version and possibly every shift as well. I figure as long as it is from a " reliable Oldsmobile" source it should pass the mustard so to speak.
Just my 2 pennies.
Old Mar 27, 2025 | 03:46 PM
442b's Avatar
I just watched this video on YT. I'm seeing the motor is the same color as mine. I'm asking myself, why would someone do such a beautiful restoration, frame off ect. and not paint the motor the correct bronze color? Before I waste my time painting my motor bronze, what do you guys think?
YOUTUBE VIDEO
Old Mar 27, 2025 | 04:21 PM
maddoctor's Avatar
YOUTUBE VIDEO 1969 Oldsmobile 442 For Sales Vanguard Motor Sales #6034
Yep, not bronze, thats 350 gold.
Trax
Oct 2, 2023 12:53 PM
MPSax
Jun 18, 2023 06:24 AM
Neil Morrison
Feb 11, 2020 04:05 PM
oldsmansugar
Sep 30, 2009 06:41 AM
rbntn
Mar 24, 2008 10:38 PM
