'73 455
Old May 26, 2024 | 02:51 PM
70RocketSteve's Avatar
'73 455
Going to look at this tomorrow. What to look for/check. tia
Old May 26, 2024 | 03:10 PM
Sugar Bear's Avatar
Does it turn freely without binding?
Oil in it that does not look spotless like it was just added or changed.
Do the cylinder heads match? The one pictured is a J.
Freeze plugs in place, any popped?
Pull the spark plugs and look at their condition.
Look at the raised casting number behind the water pump next to the oil fill tube to confirm it is a 455.
Pull a valve cover to have a look.
Look on the pad on the block below the #1 spark plugs for stamped #'s and letters.
Old May 26, 2024 | 03:20 PM
Thanks Sugar Bear! Never thought to check some of the obvious you've mentioned! It is said to be a 396021F, derivative 33M. That's all I know at this point. I assume look for "J" heads?
Old May 26, 2024 | 03:28 PM
OLDSter Ralph's Avatar
How much is the guy asking for it ? Make sure you get the harmonic balancer.
33M means:
"3" Olds division,
"_3" 1973,
"M" might mean Lansing built.
Old May 26, 2024 | 03:30 PM
33M means:
"3" Olds division,
"_3" 1973,
Asking $500 I am hoping for accessory brackets and such also.
Old May 26, 2024 | 03:38 PM
Not an unreasonable starting price with all the accessories like starter, alternator, carburetor, distributor. fuel pump and perhaps exhaust manifolds.
Old May 26, 2024 | 06:09 PM
Sugar Bear's Avatar
Look for steel shim head gaskets, if present the heads were probably never off the engine. If they were off it may have been bored.
If you can look in through the fuel pump mounting hole into the front cover cavity and see a nylon tooth timing gear it is a safe bet it has not been bored. A cell phone borescope is useful for this inspection and to look into the cylinders for corrosion and/or wall scoring.
Old May 26, 2024 | 06:31 PM
Taking notes as fast as I can Sugar Bear! I plan on getting a cell borescope on my way to look at it. I sure hope the gentleman will allow me to check all angles. I wouldn't think it would be to much to ask to pull the plugs, valve covers and fuel pump... It would be nice to find an untouched original. At least I would know what I have to work with. He said the engine came with a Cutlass that he bought years ago and since sold. Now selling the engine.
This is my maiden voyage for inspecting a used Olds engine out of the vehicle not running. Much appreciated info. Thanks again.
Old May 26, 2024 | 06:36 PM
70sgeek's Avatar
'72 Cutlass ragtop
If the water pump looks to be a replacement, may be a good chance the timing chain's been replaced at some point as well.
the script valve covers are later-model I believe - '74 or 5 I think, maybe someone else with more knowledge on that will advise
as noted above, make sure both sides have J heads, that would increase your odds the motor's largely untouched inside
I had a '73 that I ditched the J heads from for a set of untouched 1970 big-valve E heads (442 heads) - that was part of my plan for building it though then I went a different direction and sold the block but kept the E heads....
Old May 26, 2024 | 06:38 PM
Sugar Bear's Avatar
If you plan on rebuilding it and it turns over, has steel shim head gaskets and no popped frost plugs you're very likely good to go.
Old May 26, 2024 | 06:52 PM
4R5's Avatar
4R5
Question: Where is the best place to check for the steel head gaskets. Would like to check that on my '71 455 in my VC.
Thanks.
Old May 26, 2024 | 07:06 PM
Sugar Bear's Avatar
Anywhere that you can see the edge of the head meeting the block, look into the edge. If the gaskets are replacements especially FelPro Blue gaskets the difference will be obvious.
Old May 26, 2024 | 07:08 PM
4R5's Avatar
4R5
Thanks, will try that!
Old May 27, 2024 | 04:14 AM
Does the engine have a flywheel?
75 W-30 H/O
May 3, 2024 06:07 AM
Bee Saint Louis
May 29, 2023 05:34 PM
torque406
Hurst/Olds
Dec 18, 2016 03:07 AM
1973nomega
Nov 16, 2013 03:57 PM
olds4life
Apr 9, 2008 10:22 AM
