valve springs
Old Mar 7, 2025 | 04:06 PM
RowureOlds442's Avatar
valve springs
Ok i said there would be more questions do i really need to take out the inner valve springs to break in the flat tappet cam ? Johnson high lifters , comp cam , comp cam rockers . I would love to go roller but i already have the parts for the flat tappet . Thanks
Old Mar 7, 2025 | 05:46 PM
66SportCoupe's Avatar
If it's just a dampner don't remove it. If it actually dual springs then yes remove the inner spring.
Old Mar 7, 2025 | 07:31 PM
gs72's Avatar
72Cutlass S
its not the springs, its the oil. Read this, its pretty long but alot of good info.
https://540ratblog.wordpress.com/201...-test-ranking/
Old Mar 8, 2025 | 06:38 AM
Run to Rund's Avatar
I remove the inner spring and use the old formula CI4+ diesel oil with GM old formula EOS, moly lube on the lifter feet and lobes. The moly tends to plug the oil filter so I change oil and filter after the 20 minute run in at about 2500 rpm.
Old Mar 8, 2025 | 09:58 AM
BillK's Avatar
Yes. And use a break in oil like Driven BR30 or BR40. 20 years ago I would not have said that but now days it seems to really be a crap shoot on flat tappet cams and lifters.
batsisgreat
Aug 8, 2021 01:31 PM
Cruzinbill
Aug 6, 2021 04:35 AM
greenslade
Apr 3, 2011 04:50 AM
Redog
Dec 29, 2008 06:32 PM
J-(Chicago)
Oct 25, 2008 09:22 AM
