Too much?
Old Mar 15, 2025 | 01:03 PM
android 211's Avatar
Too much?
I keep building big engines for my cars with mild cams and low compression. And they still ping even on 93. Maybe I use too much advance in the distributor. I'm thinking of building a 455 for my '66 442 with 8.5:1 pistons but using a much bigger cam: a 236/241 on a 114 LSA. It will have a manual trans. I could go 3.55 rear and M-21 or I also have a Richmond Gear 5 speed with .77 OD top gear. Is it too much cam (HFT) for that low compression. I already have all these parts. I have some ported 'B' heads and headers for the car already.
Old Mar 16, 2025 | 05:45 AM
cutlassefi's Avatar
That’s not a good, viable cam and compression combo if it’s normally aspirated.
And you don’t mention anything about carb jetting and setting it up right. Make sure you’re not too lean in the higher load areas. That’ll promote detonation as well.
Old Mar 16, 2025 | 12:08 PM
BillK's Avatar
Are you using vacuum advance on the distributors ?
Post one of the combinations that is giving you trouble.
ajmanning84
Jun 23, 2024 04:34 PM
android 211
Oct 22, 2023 09:23 AM
mother$hip89
Aug 1, 2018 09:56 AM
72cutlassdog
Sep 2, 2016 05:07 AM
nonhog
Jul 30, 2012 03:18 PM
