Power Decrease
Old Apr 3, 2025 | 09:49 AM
sanche525's Avatar
Power Decrease
My 71 turns on immediately, but when I shift into gear it loses power and eventually turns off. Cutlass Supreme 455 Mondelo motor. What could it be? Spark Plugs?
Old Apr 3, 2025 | 10:12 AM
When was the last time it was tuned up?
Old Apr 3, 2025 | 01:31 PM
sanche525's Avatar
recently, but not sure it was done righ
Old Apr 3, 2025 | 01:32 PM
sanche525's Avatar
Recently, but not sure it was done right. The mechanic thinks that less powerful plugs were used
Old Apr 3, 2025 | 02:18 PM
OLDSter Ralph's Avatar
This should be a BIG clue that he knows nothing. Find someone that knows something.
Old Apr 3, 2025 | 02:21 PM
Without knowing the tune up settings used and specific symptoms no one will be able to point you in the right direction on the interwebs.
Old Apr 3, 2025 | 02:32 PM
sanche525's Avatar
The car turns on well. Sounds good, but once I put the car on reverse to get out of the garage, the car starts to sputter, then turns off. Now the car experiences a hard time to start. I finally get it to start and I rev up the engine, and then again when I shift to reverse or drive, it slowly turns off I would like to find a good mechanic, but having problems with that.
Old Apr 3, 2025 | 04:16 PM
It's a requirement you own the 1971 OEM Oldsmobile Chassis Service Manual (CSM) which 'specifically' details the service tune-up specifications for your engine. Purchase one ASAP & next time you find a mechanic, you provide the mechanic with at least the pages in the 1971 CSM which specify the tune-up specifications. The CSM is your 'bible' for your vehicle. Purchase a used paperback book, CDs/DVDs miss pages, poorly copied, unreadable, and lack detail. Additionally, an original OEM 1971 CSM contains the color wiring diagram. You need the CSM - buy it. Do you happen to have a tune-up sticker/tag located on your radiator cover plate/shroud which demonstrates tune-up specifications for your 455 cid engine? Does your car have A/C? This could be as simple as adjustments to the correct RPM setting(s) when in gear vs. in park/neutral. It could be a minor vacuum leak or a vacuum hose disconnected. It could be a minor choke adjustment. Whatever the case, you're throwing darts unless you have the 1971 Oldsmobile CSM which specifies the tune-up specifications for your engine.
There may be other manuals out there on eBay - some in better/worse condition some w/ or w/o shipping - do your research but order one ASAP so you have a leg to stand on and a card in the game.
Original 1971 Oldsmobile Chassis Service Manual
Old Apr 3, 2025 | 04:33 PM
This is representative image of a basic tune-up decal/label/sticker/tag (Vehicle Emission Control Information) normally located on the radiator top cover plate/shroud - it provides the basics. NOTE: This decal is for a 350 cid.
Old Apr 4, 2025 | 04:06 AM
BillK's Avatar
I doubt very seriously that the decal is going to apply to his Mondello Engine
Old Apr 4, 2025 | 04:43 AM
cutlassefi's Avatar
Check for vacuum leaks as well as basic tune up specs.
jmcghee
Jan 23, 2025 06:08 AM
PaulWinn
Dec 29, 2022 02:41 AM
rhaberm
Apr 30, 2018 03:51 PM
pearldawg23
Feb 14, 2008 05:08 AM
Too Slow '90
Nov 6, 2006 04:18 PM
