Dipstick wont fit?
Old Sep 30, 2024 | 11:24 AM
Kingdiamond69's Avatar
Dipstick wont fit?
I have watched multiple videos on how to install a new dipstick tube tap it in with a bolt in the top of the stick but looking at the new dipstick tube it looks like the ribs are bigger then the hole in the block?
I put in the exact motor 70 455 olds and this new tube just seems to be the incorrect size for this motor?
Old Sep 30, 2024 | 12:28 PM
I had to slightly file the bulged area to get it to fit into the hole in the block. I have read on the forum that this is very common.
Old Sep 30, 2024 | 02:43 PM
The rib area looks to be much bigger the dipstick hole which makes me think they might have sent me the wrong part .
Old Sep 30, 2024 | 03:07 PM
OLDSter Ralph's Avatar
What size are the dipstick "bulges" ? What size is the dipstick hole in the engine block ?
Old Sep 30, 2024 | 04:04 PM
The info in this thread might help:
https://classicoldsmobile.com/forums...nstall-154764/
Old Sep 30, 2024 | 04:17 PM
VC455's Avatar
Barely Registered
I did the same. I filed just enough that I could tap it into place. It has not leaked in the 20 years since then.
Old Sep 30, 2024 | 05:53 PM
Every aftermarket dipstick tube I've gotten has the two beads formed incorrectly. On the last motor I built, I had to file 0.010" off of the OD of the beads to match the diameter on the old tube. Once I did that, it went right in just like OEM.
Old Sep 30, 2024 | 06:12 PM
I don't have a microammeter but its clearly bigger then the hole.
I guess ill be taking a file to it and see it I can grind it down to fit.
Old Sep 30, 2024 | 06:33 PM
The beads are supposed to be a press fit in the hole. They are supposed to be slightly larger than the hole. The problem is that the aftermarket ones are too large.
Old Oct 1, 2024 | 06:43 PM
oletrux's Avatar
I made a little tool to install mine.
Slip it over the tube and use a slide hammer from below to tap it down into place. The small clamp will hold the tool close to the tube.
The welding rod should be nearly parallel to the nut sides. This photo shows it's a little bent.
65 F85 Cutlass
Dec 7, 2023 07:48 AM
tcarroll
Oct 23, 2014 09:37 PM
Charles Ludwick
Jan 27, 2012 06:59 PM
defiant1
Apr 30, 2011 08:41 AM
tim72
May 13, 2009 05:03 PM
