Dipstick wont fit?
Dipstick wont fit?
I have watched multiple videos on how to install a new dipstick tube tap it in with a bolt in the top of the stick but looking at the new dipstick tube it looks like the ribs are bigger then the hole in the block?
I put in the exact motor 70 455 olds and this new tube just seems to be the incorrect size for this motor?
Every aftermarket dipstick tube I've gotten has the two beads formed incorrectly. On the last motor I built, I had to file 0.010" off of the OD of the beads to match the diameter on the old tube. Once I did that, it went right in just like OEM.
The beads are supposed to be a press fit in the hole. They are supposed to be slightly larger than the hole. The problem is that the aftermarket ones are too large.
I made a little tool to install mine.
Slip it over the tube and use a slide hammer from below to tap it down into place. The small clamp will hold the tool close to the tube.
The welding rod should be nearly parallel to the nut sides. This photo shows it's a little bent.
.jpg?width=960&height=720&fit=bounds)
