Which timing chain would you buy?
Old Nov 28, 2024 | 02:49 PM
JRonGuitar's Avatar
Question Which timing chain would you buy?
Replacing original timing chain on my '77 GMC Moterhome's 455.
Any advise on which timing chain to purchase and the part number?
Was told to look for Cloyes 9-3113, Melling 40409, or S.A. Gear 78113.
Seems the Cloyes is MIA. The Melling is at $80. The S.A. is $64. Not that price matters, looking for quality.
This isn't a full rebuild, just freashing up a bit. Doubtful I will do a complete rebuild later on.
JR
Old Nov 28, 2024 | 03:07 PM
This is the one I used when I rebuilt my 455.
https://www.summitracing.com/parts/cca-2113
Old Nov 28, 2024 | 03:17 PM
v8al's Avatar
Registered Olds Owner
I used this one because of the ability to advance/retard in 2 degree increments: Cloyes Street Billet True Roller Timing Sets 9-3513X9 - $89.99
Old Nov 28, 2024 | 03:22 PM
cutlassefi's Avatar
JR
If price isn’t an issue, I would wonder why you list the prices, hmmm.
The Cloyes 9-3513-x9 or the 9-3613-x9 are your best choices. They’re normally the most accurate.
And I think a ‘77 would’ve come with a 403, correct?
Old Nov 28, 2024 | 03:51 PM
JRonGuitar's Avatar
Thanks. I have an early build "77. They changed to 403 later in the year.
Old Nov 28, 2024 | 05:07 PM
BillK's Avatar
Not sure where you got the Cloyes part number ? I come up with a C3082 I will double check in the morning at the shop. You do not need anything special. The stock replacement timing set will outlast you. For your application the double roller chain is a waste of money.
Just my opinion
Old Nov 28, 2024 | 05:19 PM
JRonGuitar's Avatar
Just my opinion
Thanks Bill. That's what I was thinking also. Appreciate the part number. Looking forward to it.
Old Nov 28, 2024 | 06:16 PM
BillK's Avatar
I just thought about the fact that we are closed tomorrow I might run by the shop at one point anyway. If i do i will double check the part number. Cloyes really does not have a good online lookup but I am pretty sure that is the correct number.
Old Nov 29, 2024 | 05:23 AM
cutlassefi's Avatar
My issue with the 3 keyway stuff is accuracy. They tend to be off enough to make a difference sometimes. Just sayin.
Old Nov 29, 2024 | 06:05 AM
tru-blue 442's Avatar
Old School Olds
.https://www.oreillyauto.com/detail/c...kit/clo0/c3082
nonhog
Feb 18, 2012 07:02 PM
mr mojo
Feb 6, 2010 06:41 AM
millwrightrice
Jul 27, 2007 02:58 PM
olds87
May 24, 2006 08:30 PM
lunatic
Jan 14, 2005 12:02 PM
