72 cam ?
Old Aug 19, 2024 | 01:43 PM
JLawrence's Avatar
72 cam ?
Does anybody know what cam would be in a 72 U code Cutlass. Is it the same as the 442? The U code car is a 455 I'm just curious what camshaft is in it.
Old Aug 20, 2024 | 03:03 AM
SY2455's Avatar
70 442 W-30
My information shows 3 camshafts for 72.
1. Part number 400165 which was the same as 70 365 hp engine.
2. Part number 409759 = L77 W30.
3. Part number 402569 which was the W30 camshaft from 1969 to 1972.
Hopefully this will help you out.
Old Aug 20, 2024 | 05:17 AM
VC455's Avatar
Barely Registered
Here are the descriptions I find for the 1972 455 cams, arranged by performance (most powerful listed last)...
400117 -- 455 4BC AT
409691 -- 455 L75 ST, L77 AT
409759 -- 455 F-85, 455 ST OAI (W-30)
Logically, I would think you have the 400117.
If Kenneth see this thread, he will give us a positive ID.
Old Aug 20, 2024 | 08:04 AM
OLDSter Ralph's Avatar
#3 P/N 402569 was the W-30 cam 1968-1970. This is the 328/328 degree cam.
Old Aug 20, 2024 | 08:51 AM
U-code cams would be consistent across the model lines.
Old Aug 21, 2024 | 08:30 PM
This s the correct info. All 1972 455s (including full size and Toro) got 400117 except for V-code and X-code cars.
Old Aug 23, 2024 | 03:23 PM
JLawrence's Avatar
Thank you all for the information
Are the springs the same across all the 455's or did the manual transmission or w-30 get stiffer
Old Aug 27, 2024 | 02:02 PM
68post's Avatar
Pretty sure That I have a #400117 GM new cam (NIB), if that's what someone needs?!
Old Aug 27, 2024 | 02:38 PM
Don't know that OP was looking for a cam ... he just wanted to know what he had.
Coastie
Apr 27, 2021 09:57 AM
72cutlassdog
Nov 18, 2020 12:39 PM
STLCRZY
Mar 13, 2015 02:06 PM
BIGBOY
Jun 2, 2014 04:24 PM
