Carb bolts....
Old Sep 11, 2024 | 01:30 PM
Tancuda's Avatar
Carb bolts....
Hi, can somebody confirm that the 2 front carburetor bolt on a stock 70 455 intake goes all the way in the plenum ? Casting #404521
Old Sep 12, 2024 | 10:30 AM
v8al's Avatar
Registered Olds Owner
On the 1970 404521 cast iron intake the two holes on the drivers side are blind. The two holes on the passenger side go into the plenum.
Old Sep 12, 2024 | 02:01 PM
Tancuda's Avatar
Ok thanks a lot v8al, will seal these 2 because believe it or not, I have a vaccum leak (a good one) under the passenger side front bolt and didn't want to remove the carb to explore.
Thanks again.
Old Sep 13, 2024 | 04:12 PM
v8al's Avatar
Glad you found that leak. The other one to watch out for is one of the two bolts that is used for the carburetor dash pot goes through to the plenum also.
Old Sep 14, 2024 | 06:24 AM
Tancuda's Avatar
Good point here, will check them also, thanks again.
jmcghee
Jan 22, 2024 11:06 AM
Chuxter
Nov 3, 2023 05:41 PM
GOSFAST
Nov 24, 2013 02:42 PM
projectheaven
Jun 29, 2011 07:12 AM
ziff396
Feb 16, 2009 08:15 PM
