67 motor mounts
Old Jan 19, 2025 | 05:57 PM
Bigdibbs88's Avatar
67 motor mounts
Hi guys- would appreciate help with motor mounts for my 67 442. The one on oldsparts looks the closest to what came off mine, but it’s listed for the 330 and 350. The others I see for the 400 and 455 don’t appear to have the “waffle” style reinforcements. Would appreciate your thoughts
Old Jan 19, 2025 | 07:01 PM
66SportCoupe's Avatar
The 66 - 67 motor mount is 2261. Period!
Old Jan 20, 2025 | 07:46 AM
Every single vendor lists Olds motor mounts incorrectly. As noted, ALL 1964-68 cars used 2261, no matter which Olds engine was installed in the car. The motor mounts must match the FRAME PADS, not the block. Every 1964-90 Olds block has the motor mount bolts in exactly the same location.
Old Jan 20, 2025 | 08:22 AM
Bigdibbs88's Avatar
Thanks for the replies. Went ahead and ordered these… will see how they work…
https://www.ebay.com/itm/36067607969...Bk9SR9S3osiQZQ
Old Jan 20, 2025 | 08:57 AM
Well, good luck. Next time order by part number, not a listed application. Once again, Anchor 2261 or equivalent, less than $10 each at most sources.
Old Jan 20, 2025 | 09:06 AM
Bigdibbs88's Avatar
Almost ordered those but they look like crap. We will see maybe I’ll regret it
Old Jan 20, 2025 | 09:14 AM
They are all the same imported crap. You can pay more, but you get the same thing.
Old Jan 20, 2025 | 09:15 AM
By the way, even Fusick just sticks a paper label over the Anchor box. You can even see the Anchor logo around the sticker.
th3ric3m4n
Sep 13, 2022 04:51 AM
SnakeBit
Non-Olds Engines
20
Sep 14, 2015 10:02 AM
steverw
Feb 22, 2013 06:27 AM
gthmcty1
Jul 23, 2009 02:50 PM
gthmcty1
Feb 26, 2009 06:21 PM
