Oil pressure sensor light on.
Hi there,
just after some clarification please as the oil pressure light is on.
On start up as per usual goes away but when I switch off and re start it stays on even when driving.
I have followed advice in forums.
Tested wire by disconnecting and earthing, light comes on.
Cleaned connection.
Still comes on.
Hooked up a mechanical oil pressure gauge which reads 60-64 PSI at idle.
Is this pressure suitable.
I found on Google someone else was 64 PSI.
I just want to confirm.
Thank you.
Cleaned connection.
Still comes on.
Thank you.
