Digital Tach hook up to distributor 75 H/O
Old Sep 14, 2024 | 02:16 PM
radiofellow50's Avatar
See pic attached. I'm supposed to hook up the "white wire" from the digital tach to the coil but I can't seem to locate the coil and I wonder if the distributor was changed out. I've read something about the changing out the old distributor for electronic ignition and if that's the case, where do I connect the digital tach's white wire.?
Old Sep 14, 2024 | 02:35 PM
Where it says tach on top of the cap where the connector plugs in.
Old Sep 14, 2024 | 02:41 PM
The distributor was not changed out - that is a factory HEI distributor. The coil is located under the cover, where the “bump” between the two LATCH indicators.
As said above, the tach connection is the terminal to the left of the battery terminal
Old Sep 14, 2024 | 03:06 PM
Closeup pic, I see a white wire, now to find the other end!
Old Sep 14, 2024 | 03:10 PM
Sugar Bear's Avatar
That wire doesn't look factory and is much bigger gage than needed for a tachometer signal.
Old Sep 14, 2024 | 04:09 PM
Well, my (un) luck is holding.. There are 3 wires that ran into the center console(probably rewired) Red, White and Blue! I checked continuity on the white wire and nothing, it's not the wire to the Tach like I was hoping. BUT I have wired the tack with the correct colored wires so will just run the white wire to the post on the Distributor.
NOW...where do I pickup the power to the tack...Since the tach was not factory, where would Hurst have tapped 12v from? I did have the tach repaired and not sure you caught that post but the repair guy said my tach took a huge voltage spike and blew out some of the components. He said to put a 1ampfuse in line on the 12+ red wire to prevent that from happening again. Thanks
Old Sep 14, 2024 | 07:22 PM
I'm assuming I can hook up an external 12v power source now that I have the white pickup wire connected to the distributor and tach should work?
Old Sep 14, 2024 | 09:28 PM
Switched power by ignition. Not always on power.
Old Sep 21, 2024 | 07:34 AM
Got the Tach hooked up to the cigar lighter temporarily. Neat having that option restored. The car also has the motor minder option!
wyteon
Aug 20, 2018 01:58 PM
ctreutel
Apr 18, 2014 02:02 PM
jjokrm
Feb 21, 2013 08:51 PM
65droptop442
Jan 8, 2013 09:26 AM
silverriff
Apr 14, 2008 07:00 AM
