Oil Leaking intake
Old Oct 14, 2024 | 11:03 AM
Gary's 2 442-S's Avatar
Gary
Oil Leaking intake
I have a problem trying toget my Edlebrock 2151 intake to seal in the rear of the engine. I have taken it off at least 5 times and have carefully tried to seal it. It leaks in the back. The heads are the Edlebrock 61025. I have used Permatex 82180 Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker | Summit Racing. Any suggestions would help. The heads and the intake are both new. I have never had this problem before trying to get the intake to seal to the heads.
Old Oct 14, 2024 | 02:50 PM
I've had good luck with "The Right Stuff" Gasket Sealer over RTV.
Old Oct 14, 2024 | 03:20 PM
x2 on "The Right Stuff" (Tom Wolfe approves this message)
Old Oct 14, 2024 | 03:29 PM
x3 on using the Right Stuff. Ditch the included lifter valley seals.
Old Oct 14, 2024 | 08:42 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
One begs the question...
Why do the gasket suppliers still make the china wall seals?
That is the first thing that hits the trash upon opening the box. Been that way 45+ years and counting.
Told ya's nothing good comes from there.
Think of all the savings of time money energy silicone injection raw material molds...wasteful.
X10 for the right stuff
Old Oct 15, 2024 | 04:42 AM
BillK's Avatar
If you haven't taken it apart yet get a bottle of die and a cheap uv flashlight. Clean it off real good with brake clean and then run it for a while. I have seen many times over the years where guys have been fooled by leaks that were actually in the front of the engine or valve covers etc and the oil always ends up at the back. Its very hard to see fresh clean oil without the die in it.
I have a set of those heads sitting on a 350 block right now. I just took a look at them and dont see anything unusual that would cause the intake not to seal.
I use either the Right Stuff or Permatex Ultra black or grey and have not had a problem.
Old Oct 15, 2024 | 05:02 AM
Bill - Spot on.
Old Oct 15, 2024 | 07:22 AM
Gary
[QUOTE=BillK;1598144]If you haven't taken it apart yet get a bottle of die and a cheap uv flashlight. Clean it off real good with brake clean and then run it for a while. I have seen many times over the years where guys have been fooled by leaks that were actually in the front of the engine or valve covers etc and the oil always ends up at the back. Its very hard to see fresh clean oil without the die in it.
Good point, I will try that
Old Oct 15, 2024 | 09:33 AM
I use Permatex Ultra Black. Never had a problem. The trick is to be sure to make the bead on the end walls tall enough - I usually have to run two beads stacked to be sure. Yeah, some squirts out. I'd rather have that than have a gap that leaks. Also be sure the RTV doesn't inadvertently get pushed out of place as you lower the intake in place.
Old Oct 15, 2024 | 11:30 AM
Another word about intake manifold gaskets. I've never been able to successfully get the "turkey tray" intake manifold gasket to seal properly. I have to cut off the sides and dispose of the "turkey tray" part.
I would recommend the same for a novice. I probably have difficulty due to my essential tremors.
Old Oct 15, 2024 | 11:50 AM
I've been working on these cars for over 50 year and have never had a problem sealing the factory metal gasket.
Old Oct 15, 2024 | 12:02 PM
I'd hardly consider you a novice Joe.
Old Oct 15, 2024 | 12:07 PM
I was 50 years ago.
Old Oct 16, 2024 | 08:10 PM
Gary
I never use those seals that come with an intake
Old Oct 28, 2024 | 11:00 AM
Gary
Update
I sent the intake back and Edlebrock sent out a new one. I will put it on sometime this week and let you gentleman know the results
Gary
Old Oct 28, 2024 | 03:41 PM
BillK's Avatar
Originally Posted by Gary's 2 442-S
Update
Gary
Where do you think it was leaking from that changing the intake will fix the issue ??
Old Oct 28, 2024 | 03:51 PM
CANADIANOLDS's Avatar
Even if the intake is a screw up at the rear from Edelbrock…Uktra black will seal it
there can be a 1” gap, it will fill it. this is an installation problem, not an intake or sealer problem. I reuse old Turkey trays multiple times with ultra Black on each China wall and the water ports, with some aviation shellac on the bead of the gasket..never fails. that’s a USED gasket.
what are you doing?
maybe do a dry install with the gasket and see how big the gap at the end wall is? that’ll give you an idea of the thickness of sealer needed
Old Oct 28, 2024 | 06:15 PM
FStanley's Avatar
Yep
Old Oct 28, 2024 | 11:21 PM
The Ultra black and grey is more forgiving because it does not set up as fast as the right stuff.
you have to move pretty fast to get everything laid out nice and intake on before a skin sets up with the right stuff.
Old Oct 29, 2024 | 02:34 AM
Gary
I know that it was leaking from the back. I believe it was not possibly milled correctly. Whatever was wrong with it was not because I sealed it wrong
Old Oct 29, 2024 | 04:33 AM
You mentioned you're using new Edelbrock heads. What head gaskets are you using? Did you have the deck milled when you had machine work done to the block?
I ask because if too much is taken off the deck or heads by the machinist it can cause intake manifold fitment issues.
Old Oct 29, 2024 | 08:06 AM
Gary
I used on the intake these gasket which Edlebrock recommended Edelbrock 7284 Edelbrock Intake Manifold Gaskets | Summit Racing
I use on the head gaskets Edelbrock 7340 Edelbrock Cylinder Head Gaskets | Summit Racing
I did not have the block deck milled since I did not have a problem with the C heads I took off and the original intake. infact I have decided that if this new intake doesnt seal properly I am going to put that original intake back on it.
Old Oct 29, 2024 | 10:38 AM
BillK's Avatar
Gary,
When you pulled the intake off the last time could you see where it was leaking in the back ? You should be able to see a "void" in the rtv or some other evidence of where the leak was. If you have not already cleaned it post a few pictures of the area across the back of the block where the intake seals.
Old Oct 29, 2024 | 03:55 PM
Gary
Gary,
Hey Bill
I have already cleaned up the RTV from the block. Yes there was a spot that was void of the RTV and that same spot was present when I pulled it before. I had an even bead of rtv in the front a back and I even had put some extra rtv on the backside of the intake. That in itself gave me pause to think the intake was not milled correctly. Trust me I was very very carefully when I put the rtv down especially after 5 times. The void spot on the rtv appeared to me in about the same location. Hopefully when I install this new one every thing will go ok. crossing my fingers. Another thing I did was to wait a couple days to cure before I started the engine. I have put on a few intakes in my lifetime and never experienced this problem
Old Oct 29, 2024 | 05:04 PM
BillK's Avatar
I simply cannot imagine what would be wrong with the intake to keep the rtv from sticking to it but you never know. Maybe some crazy impurity. I always scuff up the manifold and the block with 100 grit sandpaper and then clean it with a low voc brake clean which is mainly alcohol. Make sure whatever you are cleaning it with has no petroleum products in it.
I know theoretically they should all be the same but I really think the Ultra Grey works better than the black. Almost all of the OEMs use a grey RTV.
Hope it goes good
Old Nov 15, 2024 | 06:21 PM
Gary
This is a followup on the intake.
So Edlebrock sent me a new intake and I very carefully installed it. I put a lot of the Ultra Black sealant on the rear and let it sit for a week before I fired it up. There appear to be no leaks so far. I probably have driven the car about 60 miles since I installetd the new intake. Edlebrock did not let me know if they found a problem with the other intake and when I called them they could give me no reason if the intake was not milled correctly or not, But in my opinion something had to be wrong with the first one. crossing my fingers the problem is resolved. Thanks for all your suggestions. Much appreciated.
Gary
oldaman
May 5, 2021 08:58 AM
teamwieland
Apr 9, 2019 06:04 AM
AK71CutlassS
Mar 15, 2017 11:52 AM
Jhughes0
Feb 25, 2013 04:39 PM
1987425
Aug 4, 2012 10:05 PM
