Part ?
Old Oct 4, 2024 | 12:49 PM
jerbear2's Avatar
Part ?
O NOT WHARE TO GO WITH THIS PART ? putting A NEW FRONT SEAL ON MY 1962 88 294 please help.
Old Oct 4, 2024 | 04:33 PM
Huh?
Old Oct 4, 2024 | 06:08 PM
BillK's Avatar
Where did you take it off from ????
Old Oct 5, 2024 | 05:42 AM
Oldsguy's Avatar
Past Administrator
It looks like it started life as a standard flat washer and got put where it didn't fit and had a nut tighten down on it causing it to deform like that. Yeah, where did it come from?
Old Oct 5, 2024 | 05:52 AM
don71's Avatar
same but different
I have no idea but it does kinda look like an oil slinger.
Old Oct 5, 2024 | 09:25 AM
jerbear2's Avatar
I think behind pully or behind casing .that is whare my problem is. It my be a slinger ? and whare to put it.
Jerry
Old Oct 5, 2024 | 09:29 AM
jerbear2's Avatar
Ware will the slinger go? Jerry
Old Oct 5, 2024 | 09:39 AM
jerbear2's Avatar
I think behind crank pully. but I think it should not go there. Is it a slinger? and ware to put the slinger ?
Old Oct 5, 2024 | 10:38 AM
BillK's Avatar
I was going to also say an oil slinger but something didnt look right about it. If thats what it is then it does go on the front of the crank to keep most of the oil from getting to the seal.
Old Oct 6, 2024 | 03:55 AM
jerbear2's Avatar
I read on internet that it goes behind timing cover to sling oil on timing chain & fuel pump arm.
Thank you for come back
Jerry
Old Oct 6, 2024 | 06:32 AM
Jerry
Edit: I lost track of the fact that we were talking about a 394. Yes that looks like an oil slinger that has seen better days. It should be flat. What does the inside of the front cover look like?
Old Oct 9, 2024 | 05:15 PM
cjsdad's Avatar
Shouldn't an oil slinger have a keyway cutout? There's gotta be a key in there somewhere so the timing gear and the dampener stay put and if that goes between them it should also have a cutout for that key.
Whatever it is, it looks like it was tortured into coming off whatever it was on. Bit potato chippy...
Kiwiolds
Feb 4, 2024 03:30 PM
Kiwiolds
Jan 27, 2024 06:53 PM
arcticman
May 8, 2019 07:47 PM
Macadoo
Mar 12, 2014 06:13 AM
