Distributor test specs - help
Old May 7, 2024 | 04:52 AM
ourkid2000's Avatar
Good morning all,
Just looking for a little help interpreting the distributor test specs in my '66 Olds service manual. I'm having a hard time figuring out exactly what it's telling me on the vacuum advance side. The mechanical advance (per dist RPM) seems straightforward.......at 600 RPM you should be getting 0 to 2 degrees of mechanical advance. At 900 RPM you should see 3.5 to 5.5......and so on, got it.
The vacuum advance however, isn't quite so simple to read and I'm actually not even sure what it's saying. Maybe I'm just missing something. Is it saying that you get 9 degrees of vacuum advance at all times?
Old May 7, 2024 | 05:19 AM
rfpowerdude's Avatar
Looks like it's saying that vacuum advance starts to move (0*) at about 8-10in-Hg and all in max at 9* for 16.5-18.5in-Hg
Old May 7, 2024 | 05:49 AM
You also need to multiply those numbers x2 because the crank turns 2x times to the distributor.
Old May 7, 2024 | 05:50 AM
That is quite confusing. Does the vacuum advance go to ported or manifold vacuum?
Old May 7, 2024 | 05:59 AM
ourkid2000's Avatar
It goes to ported vacuum, from the CSM.
Old May 7, 2024 | 06:07 AM
It does not matter, those are the distributor advance specs.
Old May 7, 2024 | 06:53 AM
ourkid2000's Avatar
This sounds right the more I look at it. Thanks!
Old May 7, 2024 | 07:05 AM
ourkid2000's Avatar
Jeez, talk about confusing! I guess it's something that mechanics were much more used to seeing than someone like me who comes along 50 years later trying to figure everything out as I go.
Old May 7, 2024 | 07:35 AM
When you look at timing on the crank with a timing light, that is crankshaft degrees. So, 9* of vacuum advance at the distributor translates to 18* on the crank reading. Same for the mechanical advance.
Old Aug 5, 2024 | 03:52 PM
ourkid2000's Avatar
Well, I came across this great video showing how the distributor is tested on an old school type machine. Looks like the testing is right out of the Olds service manual as well. Specs are a bit different, I think but the procedure is pretty fun to follow (I thought so anyway). Clarifies all my earlier questions.
JPinAZ
Aug 26, 2021 04:52 PM
billrob71
Oct 17, 2018 07:29 AM
rcdynamic88
Aug 7, 2014 11:28 AM
Octania
Dec 14, 2013 08:34 AM
teqdave
Dec 7, 2013 06:53 AM
