Olds 455 non-resistor "cold" spark plug, iron heads
I am struggling to find a suitable non-resistor spark plug to suit iron heads (14mm x 1.25mm, 13/16" hex, 3/8" reach) that has a cold heat range.
I would love an NGK BP9S but they don't appear to make them.
Application is blown olds 455 drinking E85 with ICE 10amp ignition (hence non-resistor plugs required). Strictly a drag/bracket race car.
Does anyone have any recommendations? Advice from engine builders (consulted several) is that a NGK heat range 9 is a good starting point.
Thanks,
Dan
Thanks,
Dan
Is this too cold ?
https://www.ngk.com/ngk-96461-b-6l-b...g-blister-pack
Been thru that looking for plugs for perf flatheads i build. Champion and ngk have discontinued most if not all of the non resistor automotive plugs
they apparently can have the top unscrewed and resistor removed
Is this too cold ?
Have a lot of 30 new B9S coming that I found online, but they wont last forever.
