1971 442 oldsmobile - Timing and cylinder 1
Old Aug 14, 2024 | 08:34 AM
keyboard's Avatar
Question 1971 442 oldsmobile - Timing and cylinder 1
Hi guys.
I'm going to do a timing on the car, so I would like to know which cylinder number 1 is and where the mark is located to aim the strobe gun.
Thanks in advance.
Regards
Old Aug 14, 2024 | 09:29 AM
Distributor rotor facing/pointing frontwards towards number 1 cylinder (@ TDC) you start your wires from the number 1 cylinder position going counterclockwise (1-8-4-3-6-5-7-2). Ensure you're following the 1971 GM Oldsmobile Chassis Service Manual (CSM) to establish proper dwell, timing & A/F mixture.
Old Aug 14, 2024 | 09:52 AM
Timing tab indicator location
Old Aug 14, 2024 | 10:11 AM
Three images I copied from images you previously uploaded to this site. Yellow arrows indicate general location of the timing mark tab/indicator (located on engine directly above slightly right of harmonic balancer).
Old Aug 14, 2024 | 10:26 AM
Another image to provide additional clarity to which cylinder is the #1 cylinder.
Rhheritage
Sep 24, 2022 07:22 AM
84oldsDelta88
Aug 29, 2012 03:28 AM
nonhog
Feb 18, 2012 07:02 PM
The Stickman
May 26, 2010 07:37 PM
lunatic
Jan 14, 2005 12:02 PM
