Fuel pump,to filter, to carb line
Old Jun 23, 2024 | 12:25 PM
eggydrummer's Avatar
I saw several 50's / 60's vehicles at the Back to the 50's this weekend with steel fuel line from mechanical fuel pump to filter, at which point the fuel line transitioned to a small rubber chunk of hose on the inlet side of the filter, then again on the outlet of the filter, right to the carb with rubber again. I have steel line from the fuel pump to the glass bowl filter, then again from the filter to the carb inlet. Is there a reason people use rubber chunks in-line? Is using all steel line like I have, too rigid? Pros and cons of either? Thanks guys.
Old Jun 24, 2024 | 04:17 AM
Rubber hose is the lazy way out. The factory used a solid metal line from pump to carb. The two parts don't move relative to each other.
Old Jun 24, 2024 | 04:50 AM
Oldsguy's Avatar
Past Administrator
True Joe, but some people do not have the ability to bend and/or fabricate steel line. Too bad for them.
Old Jun 24, 2024 | 06:57 AM
So, I went about it the proper way then. Great to hear! Thanks for the input.
Creeves1993
Mar 26, 2018 04:32 PM
smash72
Nov 3, 2016 06:02 AM
Cutdawg78
Apr 23, 2012 06:13 PM
BStone
Aug 13, 2011 06:16 AM
Joffroi
May 10, 2011 07:26 AM
