1965 425 Engine rebuild time!
Old Aug 29, 2024 | 10:05 PM
georgec's Avatar
I just picked up a 425 Big Block for a build I am doing, putting it in a 1963 C20 pickup. The motor came with a TH400 transmission - pretty sure these are three speeds.
The engine block code is 386525A, so everything I have read leads me to believe it is a 1965 425.
Definitely need to rebuild this thing, just not sure the best route to take. I need to find a decent engine machine shop near me. I had a Ford 460 rebuilt at L&R Engine in Santa Fe Springs CA last year, but have not had a chance to get it fired up yet. They did take a long time, so hoping to find a place that may do it a little quicker.
I'm not looking for a crazy build, although I do want it to sound good. Reliability is key for me. Do you guys get pretty wild with the cams you put in your motors?
Looking for suggestions either way.
Thanks!
Old Aug 30, 2024 | 05:58 AM
Oldsmaniac's Avatar
This engine has a 45 degree cam angle so be sure to get a correct cam, most Olds BB use a 39 degree.
Old Aug 30, 2024 | 08:59 AM
Charlie Jones's Avatar
Phantom Phixer
If this is going in a 3/4 ton truck ( which is no kind of racecar ) probably a " torque " cam.
It's probably best to talk to a couple of cam makers, tell them what you have and what you expect to do with it.
And they can recommend the right cam.
Old Aug 30, 2024 | 11:00 AM
Sugar Bear's Avatar
If the TH400 is original to that engine it is a "Switch Pitch" variable vane torque converter, that is nice to have. Yes, they are 3:speeds
Old Aug 30, 2024 | 11:14 AM
Or get with Mark ( @cutlassefi on this site). He's sort of the forum's resident Olds engine build/camshaft guru.
Old Aug 30, 2024 | 01:45 PM
georgec's Avatar
That would have been awesome, however, it is not a switch-pitch.
It only has one prong on the electrical connector.
Old Aug 31, 2024 | 09:26 AM
georgec's Avatar
I did find the head casting number - it's only on one of the heads which I heard is normal.
N027585
Old Aug 31, 2024 | 09:32 AM
georgec's Avatar
N027585
some pics.
Old Aug 31, 2024 | 09:43 AM
That’s not the head casting number, it’s the engine assembly number that is stamped into the head ID pad. Those are A heads which are correct for that year engine.
Old Aug 31, 2024 | 09:53 AM
georgec's Avatar
Where are the other numbers located?
Old Aug 31, 2024 | 09:55 AM
georgec's Avatar
ok - this must be it 383821.
Old Oct 8, 2024 | 07:34 PM
georgec's Avatar
Well, I decided not to rebuild this 425; I am better off buying a crate motor for my C20 pickup. I'm sure the rebuild would cost a bunch more than a crate motor.
Any idea if there's a market for a big block 425 that needs a rebuild?
EDIT: I also have a TH400 transmission (not a switch-pitch).
Old Oct 8, 2024 | 09:36 PM
OLDSter Ralph's Avatar
Which block do you have ? What size valve lifters ? What lifter bank angle ? 39 or 45 degrees ?
Old Oct 8, 2024 | 10:08 PM
georgec's Avatar
It's an A block, and there are some numbers in the previous posts.
I am not sure how to determine if it is 39 or 45 degrees.
Old Oct 9, 2024 | 09:58 AM
When you get the lifter size/bank angle thing sorted, I am sure somebody will want it. There are people who will tell you the 425 is the best engine Olds ever built.
Old Oct 9, 2024 | 07:39 PM
georgec's Avatar
Thanks!
Now I am wondering if this is a 425 or maybe a 401? I heard from some guys that the only 425s that Buick made were Nailheads - is this true? I know I don't have a Nailhead.
The engine block code is 386525A.
Old Oct 9, 2024 | 07:44 PM
Umm ... you mean you think maybe it's a Buick?
Could you post a picture?
Old Oct 9, 2024 | 07:58 PM
georgec's Avatar
Ok. My mistake. I got confused - was talking to some guys on a Chevelle forum, and forgot that I have an Olds big block, not a Buick.
Wow - I feel dumb.
Old Oct 9, 2024 | 08:05 PM
Talking
Wow - I feel dumb.
Probably not as dumb as I felt a few minutes back.
Old Oct 9, 2024 | 08:18 PM
386525 A is the casting number for 1965 Olds 425 engine with .842 dia. lifters and 45 degree lifter bank angle.
Old Jul 13, 2025 | 06:02 PM
georgec's Avatar
If I did decide to rebuild this 425, would I be better off with the stock intake manifold or an aluminum one like Edelbrock?
Old Jul 13, 2025 | 06:39 PM
Phantom Phixer
For what you're going to do, the stock manifold will be best.
An Edelbrock will be a waste of money. Unless all you want to do is look cool.
GCH
Non-Olds Engines
19
Dec 11, 2025 10:32 AM
1965Delta88okc
May 9, 2019 08:43 AM
Tony s
Jun 13, 2016 04:34 PM
bisscrac
Jun 6, 2012 10:34 AM
40 Olds
Mar 20, 2012 03:08 PM
