1965 425 Engine rebuild time!
I just picked up a 425 Big Block for a build I am doing, putting it in a 1963 C20 pickup. The motor came with a TH400 transmission - pretty sure these are three speeds.
The engine block code is 386525A, so everything I have read leads me to believe it is a 1965 425.
Definitely need to rebuild this thing, just not sure the best route to take. I need to find a decent engine machine shop near me. I had a Ford 460 rebuilt at L&R Engine in Santa Fe Springs CA last year, but have not had a chance to get it fired up yet. They did take a long time, so hoping to find a place that may do it a little quicker.
I'm not looking for a crazy build, although I do want it to sound good. Reliability is key for me. Do you guys get pretty wild with the cams you put in your motors?
Looking for suggestions either way.
Thanks!
Thanks!
If this is going in a 3/4 ton truck ( which is no kind of racecar ) probably a " torque " cam.
It's probably best to talk to a couple of cam makers, tell them what you have and what you expect to do with it.
And they can recommend the right cam.
Well, I decided not to rebuild this 425; I am better off buying a crate motor for my C20 pickup. I'm sure the rebuild would cost a bunch more than a crate motor.
Any idea if there's a market for a big block 425 that needs a rebuild?
EDIT: I also have a TH400 transmission (not a switch-pitch).
I am not sure how to determine if it is 39 or 45 degrees.
When you get the lifter size/bank angle thing sorted, I am sure somebody will want it. There are people who will tell you the 425 is the best engine Olds ever built.
Thanks!
Thanks!
The engine block code is 386525A.
Could you post a picture?
386525 A is the casting number for 1965 Olds 425 engine with .842 dia. lifters and 45 degree lifter bank angle.
