1967 400 .921 lifters
Old Jul 23, 2024 | 08:57 AM
Lykinsj's Avatar
I posted on here a few days ago about my customers Oldsmobile and the lifters allowing too much oil to go to the top end causing excessive smoke out of the exhaust. I’ve checked oil pressure and I’m at 55 to 60 psi at idle which is way too much. I’ve tried contacting the company that sent me these lifters they say they don’t know about this issue. Someone gave me the number to a company that directly sells Johnson lifters but I have read on here even those have problems oiling too much at the top. Any ideas?
Old Jul 23, 2024 | 08:59 AM
Is that 50/60 once the engine is completely warm?
Old Jul 23, 2024 | 09:03 AM
Lykinsj's Avatar
50 to 60 at beginning of start up. Not warm yet
Old Jul 23, 2024 | 09:08 AM
Cold, you are going to get those pressures. You need to see what it levels off at when fully warmed up. How long has the engine run for? If this is a new build, it takes time to burn all of the junk out of the exhaust system that usually collect when an engine is removed and reinstalled.
Old Jul 23, 2024 | 09:09 AM
heatmup's Avatar
My truck with a crate L31 350 has 80lbs cold and 50lbs warm cruise. You're fine
Old Jul 23, 2024 | 09:30 AM
Lykinsj's Avatar
I’ve pulled the valve covers and there is oil shooting out over the fenders from the excessive pressure from the lifter. There’s so much oil up there it’s drowning the valves.
Old Jul 23, 2024 | 12:59 PM
My engine (that was rebuilt in the 90s) has 50-ish PSI at startup and runs around 40 PSI during warm cruise. I don't think your pressures are unreasonable for a fresh build.
Old Jul 23, 2024 | 01:01 PM
Lykinsj's Avatar
I guess pressure isn’t my problem it’s the metering in the lifters. It’s shooting oil through the pushrods and drowning the top end. I’ve been through 2 sets of lifters trying to solve this issue
Old Jul 23, 2024 | 01:08 PM
If you have the old lifters, is it possible to swap the metering disc onto the new lifters? I'm assuming the old lifters didn't do this and therefore have a smaller hole in the metering disc.
Old Jul 23, 2024 | 01:11 PM
Lykinsj's Avatar
sadly I don’t have them. I trashed the old ones not thinking this would be such an issue. I wish there were just metering disks I could purchase from somewhere
Old Jul 23, 2024 | 01:19 PM
66-3X2 442's Avatar
The Johnson lifters are the best on the market. If you have true Johnson lifters and still pumping too much oil to the top, you have another problem.
Old Jul 23, 2024 | 01:25 PM
Lykinsj's Avatar
What could be the issue other than lifter metering?
Old Jul 23, 2024 | 01:41 PM
66-3X2 442's Avatar
Not sure but have used way too many Johnson lifters without any issues. Have you used a verified set of Johnson lifters and I'm not talking about what Clay Smith says. Clay Smith could have sold a set of lifters and somebody swapped them out for Chinese junk and returned them. Far fetched but until you try a set of verified Johnson lifters from HyLift Johnson/Topline I won't believe they are the problem.
Old Jul 23, 2024 | 04:28 PM
66-3X2 442's Avatar
I have 15 used Johnson lifters that you can buy and use the metering plates out of if you want to try that.
Old Jul 23, 2024 | 06:43 PM
fleming442's Avatar
Wouldn't restricted pushrods be way easier than pulling the intake and lifters? Maybe I'm stupid
Is there excessive play in the guides? Got seals? .
My new engine has 80-100 cold, and the biggest problem I have is leaking valve covers (stock repro the spacers and 2 gaskets). I'm going back to the cast aluminum tall and a catch can. Hopefully, that helps.
Old Jul 23, 2024 | 07:28 PM
Sounds like an excellent idea to me.
Old Jul 24, 2024 | 07:27 AM
CustomBruiser's Avatar
My 455 with Crower lifters also shoots oil over the fenders if I run it with the valve cover off. Is this considered excessive? I have not seen any issues with it at this point.
Old Jul 24, 2024 | 12:44 PM
Run to Rund's Avatar
As I posted in the other thread, I use plates with one offset 0.055" hole, solid lifters, stock rockers. Back in the 1970's when I first used the block, I drilled and tapped each feed hole at the lifters for an 8-32 set screw having a 0.040" hole, red Loctite on them. You can tap directly but the factory feed holes are a bit small (0.125") for an 8-32 tap and you may break the tap. Drill them a few thousandths larger first. Spec is 0.136" = #29. I still have two cam and lifter sets, from the 1970s. One cam is the big Comp XE hydraulic and the other is a custom Comp solid, in case a reader of this thread is interested. Both are broken in, lifters kept in order.
Lykinsj
Jul 19, 2024 10:34 AM
Railguy
Dec 10, 2016 06:12 PM
taa442
Jun 8, 2012 12:01 PM
Kevin W
Apr 27, 2012 05:50 AM
mr-tom
Nov 30, 2008 04:27 PM
