distributor gear
Old Nov 28, 2024 | 03:26 AM
6844268's Avatar
distributor gear
does anyone have a source for a composite distributor gear? bronze gear already showing wear
Old Nov 28, 2024 | 03:45 AM
fleming442's Avatar
https://www.bopengineering.com/
Old Nov 28, 2024 | 07:24 AM
6844268's Avatar
Yep 200.00
Old Nov 28, 2024 | 07:34 AM
fleming442's Avatar
They're not cheap, but they're the only game in town. I wasted way more than $200 on brass gears sold as bronze. Someone should hang for that crime against hotrodding!
Old Nov 28, 2024 | 07:55 AM
OLDSter Ralph's Avatar
Let me ask you, what is the composition and hardness of these BOP gears ? Are they magnetic ?
Old Nov 28, 2024 | 07:56 AM
6844268's Avatar
Did some reading about the different gears per application, I just pulled the disc out to have it redone and noticed some wear aleady, motor only has 50mi since rebuilt. I woulda never went bronze if my dis builder mentioned melonized, but composite is better I guess?
Old Nov 28, 2024 | 08:00 AM
6844268's Avatar
https://www.enginebuildermag.com/200...tributor-gear/
This link explains some things
Old Nov 28, 2024 | 12:40 PM
fleming442's Avatar
As far as I know, melonized is a version of cast iron. My engine builder had one fail and trash an engine. I'll stay away, thanks. It's bad enough that the wear dust from a bronze or composite gear goes through the oil pump.
There also seems to be some debate on whether one is required, depending upon the camshaft manufacturer. Again, $200 for a composite gear is cheap insurance. Mine has very little wear after about 15,000 miles.
The previous gears i was getting were made by Comp and Allstar. Both were advertised as bronze, but experienced massive failures after a couple hundred miles, unlike the previous actual bronze gears that were good for a few thousand (every oil change). I assume that the newer gears are actually brass, judging by their yellow color.
Old Nov 28, 2024 | 02:25 PM
6844268's Avatar
Yes it has a coating on it, I will be going with composite with all the headaches I been thru lol, I think my bronze gear came from jegs, thanx for your input 👍
joeyg
Jan 8, 2024 10:41 AM
Andy
Oct 10, 2023 07:55 PM
Olds 65
May 21, 2021 07:58 AM
big man
Apr 1, 2018 08:40 AM
1970Olds442
Nov 24, 2017 07:15 AM
