distributor gear material
Old Jan 4, 2024 | 03:08 PM
joeyg's Avatar
I'm upgrading my ignition to HEI, anyone know what type of distributor gear material that should be used with a Lunati cam part number 20429909?
Old Jan 4, 2024 | 03:55 PM
OLDSter Ralph's Avatar
Couldn't Lunati tell you ?
Old Jan 4, 2024 | 04:08 PM
joeyg's Avatar
I tried that but was put on hold and gave up...
Old Jan 5, 2024 | 12:36 AM
fleming442's Avatar
https://www.bopengineering.com/olds_v8.shtml
Old Jan 5, 2024 | 02:58 AM
Is it a billet cam or a cast blank?
Old Jan 5, 2024 | 04:33 AM
BillK's Avatar
All the catalog says is "requires distributor gear upgrade" The only Olds distributor gear they show is bronze. I think I would keep trying to reach them to make sure. You could try calling Chris Stroub at Straub technologies and ask him. He has all of the Morel gears and is pretty knowledgeable as to which cams need what gear.
https://straubtechnologies.com/categ...tor-gears-olds
Old Jan 5, 2024 | 08:15 AM
oddball's Avatar
You'll likely need a bronze or melonized gear. Can be hard to find depending on which distributor shaft you have (stock 0.491 or aftermarket 0.500). When I last went searching years ago it was also a pain on the aftermarket gears because some manufacturers weren't clear on whether the gear was melonized or not.
Old Jan 5, 2024 | 03:54 PM
cutlassefi's Avatar
Correct.
if you have a .500 gear then you can just buy an MSD replacement gear. They’re melonized and seem to work real well.
Old Jan 5, 2024 | 04:19 PM
joeyg's Avatar
Thanks everyone I'll get a new gear. BTW trying to contact Lunati support is ridiculous, wait times are over an hour...
Old Jan 8, 2024 | 10:41 AM
rfpowerdude's Avatar
Correct.
if you have a .500 gear then you can just buy an MSD replacement gear. They’re *memorized* (melonized) and seem to work real well.
I think your iPhone autocorrect thinks it knows more than you do, Mark.
Olds 65
May 21, 2021 07:58 AM
big man
Apr 1, 2018 08:40 AM
1970Olds442
Nov 24, 2017 07:15 AM
cdrod
Sep 24, 2015 08:00 PM
drjr56
Sep 9, 2012 08:05 PM
