PDA
View Full Version : Wheels and Tires
Pages : [1] 2 3 4 5 6 7
  1. Help identifying Wheel brand/style
  2. 15” steel wheels (poverty) for ‘70 Cutlass
  3. Wheel size question
  4. Cooper Cobras
  5. Can SSI beauty rings be broken down to repair dents?
  6. 1966 442 Tire Opinion?
  7. 1969 442 Factory Red Stripe Tires
  8. What tires on factory ss1 14 x 6”
  9. Stick-On Wheel Weights
  10. parts
  11. When to replace tires?
  12. Cragar wheels size (also may be SSI wheels)
  13. Wheel upgrade options
  14. Wheel trim bezel question for you guys
  15. Considering something out of the box for 14" tires
  16. 70 Super Stock 2 wheels paint color
  17. Rim center cap installation
  18. 1970 SSII Center Cap Emblem
  19. General Altimax RT45
  20. Help ID this wheel
  21. 1970 442 convertible wheel color
  22. 1966 3 Bar Spinner Hub Caps What models ?
  23. 68 SSI wheels and tires
  24. SSI wheel replacement
  25. Trim Ring Polishing Recommendations
  26. Wheel Identification
  27. 1957 olds super 88 hub caps
  28. 1965 Olds 98 with new wheels
  29. RWL tires
  30. SSll rims
  31. Coker Wide Oval inquiry
  32. Poverty hub cap question 1970
  33. 71 Cutlass Supreme Tire Rubbing Issue
  34. 15x7 olds rally wheels
  35. 14x7 wheels
  36. SSII 14 X 6 Trim Ring Help Needed
  37. 67 cutlass extended wheel studs
  38. Wheel primer ,Thornton Paint for SSII
  39. Wheel / tire fit for 67 cutlass
  40. Old American Racing wheels on the 72 Cutlass
  41. Tires
  42. Wheel recommendations for 1978 98
  43. U.s. mags Indy 8.5x15: documentation needed
  44. Put some wheels and tires on the 73
  45. Factory SS wheels size 15" by?
  46. Looking for 7.75 by 14 Supersports
  47. G70-14 Wide Ovals
  48. Tire size for 15x7
  49. Struggling with wheel fitting
  50. Will they rub?
  51. Wheel code off 1970?
  52. 15 " steel wheels
  53. 1970 steel wheel code
  54. 1970 Delta 88 Spare tire and jack tie down
  55. Show me your rims
  56. SSIII Wheel Balance Question on Missing Hub Cover Screws
  57. Coker Now Selling 1" WW in a 205-75-14
  58. School me on SSI’s
  59. 70 Cutlass Wheel and Tire Sizes?
  60. Stance setup- any guesses?
  61. Wheel date code?
  62. Tires
  63. Crager SS Wheels
  64. Chevy Truck rally wheels on an Olds 98
  65. Tire rub on sway bar
  66. 1967 442 correct wheels
  67. Wheel Paint Opinions Please
  68. 235/60-15s front wheels?
  69. P275/50-15 tires
  70. How old is this tire?
  71. Race wheel sizing and hub size
  72. Another tire size question, 1971 442
  73. Tire size 71 18x10 and 18x8.5
  74. Tire size
  75. 66 Cutlass
  76. Need help with wheels
  77. Having SS wheels straightened
  78. Tire Size Question
  79. 295-55-15 on 10"" rim !
  80. 67 Delta-
  81. Wheel tire size
  82. Why did Olds use 14" rims?
  83. New 15x10 AR500s arrived today
  84. Oem tire size
  85. Space saving spare needed
  86. 15” SSII and SSIII Widened Wheel Source
  87. Need Help Finding What Type Of Rims These Are
  88. 68 ssii
  89. Brakes Pulsating
  90. 14 in 4x4.5 wheels needed
  91. Tire size front rear question
  92. Rim question for my 79 cutlass
  93. Lug nut won't tighten up
  94. Tires (still) ain't pretty. Original looking but drivable radial?
  95. Tire and wheel information wanted 67 442
  96. Lug nut size ?
  97. OE tires
  98. Dumb tire size question
  99. VHT compare to Thornton 1970 argent grey need advice
  100. Olds JJ Rally wheels
  101. 2 Gold Vintage Oldsmobile Cutlass Rally wheels for sale 15x7
  102. Looking for Opinions on 1.5" WW Tires
  103. Question about my new CRAGAR SS direct drill wheels
  104. Upgraded tires on my 67 Cutlass
  105. 15" wheel project.
  106. New Tires - Need recommendation
  107. Tire pressures
  108. TPMS (Autel) for Olds Rally wheels?
  109. Another tire thread.
  110. Quick question about tire options
  111. BMW rims
  112. A3 and DG Chevy rally wheels, help identifying
  113. Wide tires
  114. Slightly Bent Rim
  115. American Racing Torq Thrust - 15" Diameter
  116. Goodyear/Polyglas G70 Tire Pressure
  117. Wide Oval Radial - Recommended Pressure
  118. Cragar ss rims on my 68 olds
  119. I need help with tire size and rim sizes for a 69 Cutlass S
  120. 17inch ss wheels
  121. Do you have tires wider than 325 on your 68 or 69 Cutlass/442?
  122. Hubcap Identify
  123. 15x7 said trim rings
  124. Radial T/A vs Redline
  125. SSII or SSIII?
  126. Super Stock IV polycast ???
  127. Wheel color inside & size ?
  128. Wheel size & where 2 buy
  129. Guess This Hub Cap (?)
  130. 1970 correct tire size
  131. 1966 cutlass supreme center caps
  132. 84 Delta 88 15 inch rims fit my 1969 Delta
  133. 64 cutlass wheel size
  134. 70 442 tire fit? 16x9.5, 4.5 backspace
  135. Stock Vista Cruiser Rims
  136. SS IIs and SS IIIs
  137. 69 cutlass s convertible wheels
  138. tire info
  139. Redline tire date code
  140. REmoving Tire Protection Coating
  141. WANTED 70 SS II wheels, willing to trade or buy
  142. 15x8 SSII Wheels??
  143. What is the RPO code for this hubcap (1968 Cutlass)?
  144. Cutlass rim score
  145. Delux hubcaps
  146. Tire size input / comments
  147. Code Stampings for 67 442 wheels
  148. Change lug stud
  149. Larger than 315 rear tires 70-72 Cutlass S?
  150. Correct Current Tire Size
  151. CRAGAR Custom Shop for wheels will be opening back up in 2024!
  152. Factory steel wheel size 1977 Cutlass S Sedan
  153. New Tires
  154. Rally 2 wheel decode rim loading
  155. Wheel size caliper interference
  156. TPP 15x7 aluminum ss1
  157. Diamond back or Coker
  158. Need some input
  159. Wheel spec identification help
  160. 1957 Oldsmobile - what newer style rims fit??
  161. Cooper Cobra New Tire Purchase
  162. 235/70R15 Tires
  163. BF Goodrich TA/Radials
  164. Wheel Suggestions for 72 Cutlass
  165. New wheels for my 71 98
  166. Will 15x7 Cutlass rally wheels fit my '72 98
  167. Help ID 1967 SS1 810 C disc or drum?
  168. Wheel Vintique SS1’s 15” x 7” conflict w disc brakes
  169. Need Tires - 1968 Cutlass S Convertible
  170. SS1 trim ring question
  171. 66 Starfire new wheels & tires: comparing old & new
  172. Jack Mounting
  173. Driving the mid-60’s big car speedos: keep a hack or go factory?
  174. 69 Hurst olds tired
  175. Tire Comparison Calculator - not sure whether to trust or not…
  176. Hub caps to fit 15” rims.
  177. Year One 17x8 SSII
  178. What are these wheels worth. May be going for sale.
  179. wheel offset nightmare
  180. Tire and wheel upgrade 68 Cutlass Resto Modish
  181. SSII Wheel Face/Center Sizes
  182. 65-70 Big Car Wheel & Tire Combo Suggestions?
  183. Wheel Color decision / Dog Dish
  184. Wheel Trim Rings from Hell!
  185. Wheel widening
  186. Anyone running 3.79" backspace on Torq thrust rear?
  187. Options for taller tires
  188. Center hubs
  189. Modern wheel choices that are reminiscent...
  190. Wheels designed 10-15 years ago, now US Mags
  191. Whitewall Tires for '55 S88
  192. Good quality SS1 wheels
  193. Rim beauty rings
  194. 1972 Olds 98
  195. The Parts Place SSI wheels…
  196. Wide White Wall tires
  197. New wheels What should Indo.
  198. SSII wheels Delta 88 fit?
  199. Was it possible to get 15" rims/tires on a 69 Cutlass or W31?
  200. Jack Stowage - 1955 Super 88
  201. '72 Vista Cruiser Wheels and Tires Pt 2
  202. 1968 Delta 88 wheel options ?
  203. 1967 Cutlass Holiday Coupe Original Wheels?
  204. Wheel Identification help
  205. SS Wheels for '72 Vista Cruiser
  206. Firestone Wide Oval bias ply
  207. Olds F85 ‘66 Size Tires
  208. Widening Stock Wheels? Question
  209. Painting Yearone 17 in. SSII chrome wheels
  210. Who makes the best trim rings
  211. Has anyone ever modified steel wheel to accept hubcaps?
  212. 1967 P05 Super Stock Wheel Option
  213. Powder coating SSII wheels???
  214. 1970 98/D88 Wheel Cover Retaining Clips
  215. Bfg 235-60-14
  216. Need help with lug pattern + wheels - 1964 NinetyEight
  217. 71 oldsmobile cutlass Supreme tire options
  218. 1970 Wheel Cover Retainer Clips
  219. Wheel Size and Backspacing for a '70 98LS
  220. ISO 1964 F-85 Steel Rims
  221. How to get 15x10 wheels to fit the back on a 68 442?
  222. Correct Tire & Wheel Size
  223. Wheel vintiques ss1 trim rings
  224. SSII vs SSIII is color based, not center based.
  225. G body rally wheels on A body
  226. 68-69 442 Cutlass SSII wheel details
  227. Replace SSIII Bezels
  228. Can you help identify the wheel in the photo?
  229. Vibration Comes and Goes
  230. 15x9 wheels
  231. '68 442 Convertible Wheel anomaly
  232. 4 lug wheels.
  233. 17s on a 1966?
  234. wheel studs
  235. G Body 15x7 chrome wheels
  236. Center caps
  237. Larger rear wheels 73-77 cutlass
  238. 1971 wheel size
  239. Help with tire size
  240. Wheel Identification
  241. Fitment problems
  242. What 14 x6 wheel Whitewall to Buy?
  243. Super Stock 1 restoration
  244. '67 Cutlass front disc brake conversion
  245. 1962 Starfire
  246. Centre cap decal
  247. Decode Rally wheels 15x7
  248. New wheels
  249. 225
  250. Lug Nuts
