Click Here
1966 3 Bar Spinner Hub Caps What models ?
Old Nov 19, 2025 | 01:07 PM
john mann's Avatar
Hi, I Just picked up a set of 4 1966 Olds 3 bar spinner hub caps 14" Could somebody out there tell me what model's these were offered on,
The only model i know these came on was the 1966 starfire, any info would be appreciated, Thanks john..
Old Nov 19, 2025 | 05:54 PM
The 1966 SPECS booklet shows that the RPO N95 simulated wire wheel covers with three bar spinners were available on every A-body and B-body car that Olds built in the 1966 model year.
Old Nov 19, 2025 | 06:12 PM
john mann's Avatar
WOW !!! Thanks so much Joe you have always pulled thru for me John...
Old Nov 19, 2025 | 06:42 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Upload pics.
There were subtle differences.
Be interested to see what you have
Old Nov 19, 2025 | 07:37 PM
john mann's Avatar
Sure, i ll take some pics this weekend and put them on here, john..
Old Nov 20, 2025 | 04:12 AM
Bfg's Avatar
Bfg
I think the only reason they weren’t offered on the Ninety-Eight is because they wouldn’t clear the skirts.
Old Nov 21, 2025 | 03:26 PM
john mann's Avatar
Here are the pics, Never cleaned them could use it,
Old Nov 22, 2025 | 03:48 AM
LuckyLuke's Avatar
The factory code for the wheel covers was N95, I was always interested in what effect they have on wheel balance :roluje:
I use the P02 type myself and they are made up of three parts and are quite heavy
Old Nov 22, 2025 | 06:38 AM
john mann's Avatar
Hi Luke is this my style then the P02 Thanks for your reply john..
Old Nov 22, 2025 | 09:25 AM
I thought they all have the flat black paint treatment on the stainless part of the rim under the spokes. I have seen at least 3 variations of these now a 4th unless someone messed with the black paint on yours.
The top cap is a 15". The spinner sticks out significantly more than the bottom cap which is a14".
Old Nov 22, 2025 | 09:37 AM
If you think the Olds or any similar wire cover of the era are heavy, they weigh 1/2 of what the Riviera SD, Vette/Impala/Monte P02s weigh. They are 8lbs. But they are balanced from the factory.
Note the weights
Old Nov 22, 2025 | 11:43 AM
LuckyLuke's Avatar
Here are the types of factory Oldsmobile hup caps for 1966
Here are my type P02s where I restored the chrome on the middle part.. but I sanded the original black matte base between the spokes and polished it to a shine.
Old Nov 22, 2025 | 12:06 PM
john mann's Avatar
Wow, Thanks you guys for all the info, pretty sure these were not messed with they look like they have never been touched, but who knows almost 60 years later, john..
Old Nov 26, 2025 | 08:16 AM
RAMBOW's Avatar
Ben
Pic of my old 66 when it was brand new (Original owner sent me pic), came with the wire hubcaps.
He told me he took them off after a couple years because they "squeaked" really really badly.
Old Nov 27, 2025 | 09:25 AM
cfair's Avatar
I always liked the 3 bar spinners. My 98 convertible came with the cheapest caps. I can confirm that unless you get creative about wheel width and spacing, the fake wire wheel covers won’t clear the skirts of the ‘66 98. They work great on my ‘66 Stafire, but yes, they do squeak a bit.
My wife calls them “dog killers”. Remember what happed to that poor Mustang in the Alps in Goldfinger?
These covers can be easily disassembled using a 1/4” hex head on a power screwdriver, but there are at least 2 lengths of screws which can sometimes get stuck and twist the tops off. The diecast chrome centers are secured with 4 screw and can be reused on many GM wire wheel covers like the 15” 1049B used on ‘71 Monte Carlos. That’s what I did to make my 15x8 Starfire wheels look ‘66 factory-ish.
The thing that wears out on these rather heavy hubcaps are the spring steel clips on the outer edge of the cap itself which holds them fast to the wheel. If they are loose, rusted, broken or otherwise damaged, the caps can fly off at speed with no warning. Ask me how I know… so these days I have a few spares around ready to go in case of surprise.
Most of these caps have 2 lengths of spokes which can be removed for cleaning/polishing/straightening. Once the centers are off, and the spokes are soaking in Simple Green, or you’re polishgin them with #0000 steel wool, you get curious about repainting the actual caps in flat black, or maybe a satin black per your preference. I used wide blue tape to mask off the circular edges, then just sanded and spray-bombed them.
You may also get curious about putting the caps on your buffer and really polishing them up.
To minimize the squeaks, you can tap the “ears” of the punched holes that the spokes fit into back into their punched pyramid shape to recreate holding pressure on the spokes. Looking at the cap from the back side, tap the each hole’s 4 “ears” to create pressure on the spokes. I considered using silicone sealant to glue the spokes to the caps as an anti-squeak measure, but haven’t done it yet.
Upshot is they’re heavy, can squeak, but are great for a period look. Thanks to GM, we can mix and match parts to some degree.
Cheers
Chris
67abody
Dec 21, 2024 06:49 PM
Andy
May 1, 2024 05:22 PM
67abody
Jan 17, 2016 04:46 PM
Bfg
Jan 28, 2014 03:01 PM
whitey
Mar 10, 2010 03:18 PM
