PDA
View Full Version : Wheels and Tires
Pages : 1 2 3 [4] 5 6 7
  1. Help to confirm American racing Wheel size
  2. Wheel Size Debate - 15's or 17's
  3. 1972 Cutlass Supreme Tire Size
  4. hubcaps too small, what do i do!!!!!
  5. run away hub caps!!!!
  6. spare tire?
  7. Tires and wheels are on the way!
  8. Identify SS1 SS2 Wheels
  9. Headers and tire clearance
  10. Vintiques 52 Olds SS1 Question
  11. Looking for offset figure
  12. Psi
  13. Are 205/70R14 too narrow for 14x6 rims?
  14. Here we go again, sorry.
  15. Biggest tire for 18x9.5 wheels for 70 Cutlass S
  16. Help me identify these hubcaps
  17. Storing for winter
  18. wot other make has the same stud pattern as 64 olds 98???
  19. 1955 Olds OEM 15" Wheel Backspace
  20. Rim sizes for 72 cutty
  21. SSIII Stamped Wheel Codes
  22. Wheel color options.....
  23. SSII or SSIII Chrome wheels wanted
  24. correct color code for rally wheels
  25. 1967 Cutlass wheel fitment
  26. If You Are Deciding Whether To Go With SS1's Or SS3's
  27. Powdered the 14x5s
  28. 68 Cutlass New Wheels and Tires Input
  29. 65-70 Big Car 15x8 wheels?
  30. 14 x 6 SS1's - chrome
  31. Plastic wheel guards
  32. G-body-Wheel and tire discussion
  33. Wide wheels
  34. 14" SSII for disc brakes
  35. Will it fit? S-10 Wheels and Tires
  36. rally wheel bezels
  37. What is the max rim and tire size for a 1948
  38. Tires code differences
  39. SSIII Torque Setting?
  40. I put some 18" Wheels on my 65 Cutlass/442
  41. Inches away from buying new tims and tires... 76 442
  42. Tires
  43. Bias Look radials
  44. New Wheels and Tires for 76 442
  45. wheels to fit 87 cutlass supreme brougham
  46. delta88 1967 wheel bolt pattern
  47. Refinishing SI and SII wheels - also tire problem
  48. tires and wheels
  49. Tires and wheels for 1963 F85 Cutlass Vert
  50. 70 442 wheel size
  51. 215/75/15 on 72 Cutlass?
  52. Got me some Chevy 15x7" Camaro wheels for my Delta
  53. Tires for 65 F85 with 17" rims
  54. Tire sizes that fit a 67 Cutlass
  55. 15 inch SSI rims
  56. wheel backspace
  57. How do I remove this '68 wheelcover?
  58. Will these fit my '69 442?
  59. white walls
  60. G-Body Cutlass 225/70R15 front and 255/70R15 rear
  61. What you think about this combinations?
  62. What is paint code for 1968-9 rally wheels.
  63. 1966 Oldsmobile Delta 88
  64. Exiter wheels on a W car
  65. what in God's name...
  66. SSII/SSIII wheel bezel rings
  67. Need some rim guidance
  68. wheel studs
  69. cragar ss wheels
  70. 14x7 Rallye Wheels
  71. Coke and Foil really works
  72. GM wheel differences?
  73. New Tires and Wheels
  74. New wheels for a 75 Delta 88?
  75. 62 olds 88 wheels and nuts
  76. Question for the Trailer Tire Experts
  77. 1984 Toronado
  78. tire size question
  79. 1986 442 Wheels
  80. 14x7 Rallye Wheel Help
  81. 17x9's with a 5 inch backspacing on a '69 Cutlass
  82. Tires
  83. 67 cutlass supreme rims
  84. Wheel discs or wheels
  85. Widest tires for '69 Cutlass with 10x15 wheels?
  86. restoring the wheels of 84 hurst olds
  87. Will a steel rim off a Caprice make a good spare?
  88. 1969 Cutlass SSI Lug Nuts ??
  89. 65 vista cruiser tire size question
  90. 1972 Cutlass backspace help, 18x8 & 18x10
  91. 68 Wheel/Brake Hubs
  92. finally olds rims :)
  93. raised white letters yellowing
  94. 14x7 (not 6) Snap-On center SSII
  95. Sticky tires...
  96. 68 rallye wheels
  97. Wheels and Tires Help
  98. 255/50/R16's on a 68 442?
  99. Aftermarket Wheels for 63 Starfire
  100. 255/60-15 Tires
  101. 1968 Only SSII Bezel Paint Color Question
  102. What color to paint my wheels?
  103. 17's on a 77 cutlass? 17x7? 17x8?
  104. wheel sizes for my grand daddies 67' 4 Door
  105. Let's see your 17" to 20" tire and rims!
  106. Bolt Pattern Help
  107. 15" through 20" SSI Wheels
  108. Wheel covers and hubcaps..
  109. 5x5 day van wheels on full size 88
  110. Chrome smoothies
  111. "knockoff" knockoffs
  112. Trim ring question..
  113. Best rear tires for street
  114. Tire size for 77 Cutlass
  115. SSII Color
  116. Will it fit?
  117. 1963 98 Tire size
  118. 17" x 8" Wheel fitment on a 1965 Cutlass
  119. Cooper Cobra Radial G/T vs BF Goodrich T/A
  120. Aftermarket Wheels 16" and larger
  121. 65 Jetstar 1 Wheel info needed
  122. Ss iii bezels
  123. 14 x 6 RIMS JK STAMP 810 STAMP 69
  124. 15X7 stock steel wheels
  125. Front Wheel Fitment
  126. best tires for quality riding
  127. just bought some rims
  128. 275/60R-15 on SS III 15X7
  129. American Racing 200s
  130. Speedo calibration
  131. Using Buick SS1's on my '72 Cutlass
  132. Rally Wheel Question
  133. Futura GLS Super Sports
  134. 15x10 Weld Alumastar 6" back space?
  135. Wheel Identification
  136. post 1972 SS wheels question
  137. Hubcap centers
  138. Removing Center Insignia
  139. How did I round out my SSI lug holes?
  140. 14" Wheels on a Cutlass Woes.
  141. Wheel tourque
  142. Staggered wheels on a 71
  143. picking up a 1961 f-85 this weekend!
  144. Looking for US Indy wheels
  145. Is This The Correct Wheel Bezel For A Jan 70 SS2?
  146. Crager Universal SS rims.
  147. Color opinion requested
  148. tire date codes w pics
  149. No trying to beat a dead horse.
  150. Weld Prostar shank lug question
  151. Wheels with Right Stuff Brakes
  152. Pro tour tire/rim size
  153. Help - How can I clean these up?
  154. Tire size on 70 442
  155. Looking for SSIIs
  156. What size are my rims
  157. 14" SSII's rubbing on '88 Cutlass.. Help!
  158. stock wheel size
  159. '70 - '72 SS II Wheels with FE2 Suspension
  160. Lugnut Brands
  161. wheel/disc brake caliper interference?
  162. Help with tire size for Musclepalooza drags
  163. What size tire?
  164. Homemade tire fitment tool
  165. No more aftermarket SSIII's
  166. Another 68 Tire/wheel opinions wanted
  167. 70 Cutlass 15 inch wheels & trim rings
  168. What size wheel?
  169. Finally some progress after a looonnnngg winter..
  170. SSIII questions
  171. In need of a favor
  172. Source for 17 inch wheel trim rings
  173. SSII question
  174. 76-77 cutlass hubcaps on 69 delta 88
  175. '64/'65 Cutlass....what rims and tires larger than stock
  176. BFG or MT?
  177. which 15 in. rims?
  178. 15 x 10 SSII Rallye w/Bolt On Centers
  179. Full Size RWD - Standard 15 Inch Steel Wheel Width
  180. Dangerous or not?
  181. wheels and tires
  182. Which hubcaps?
  183. Tires for 69 Cutlass
  184. 16" rims
  185. Why not a cutlass supreme????/
  186. Level of gloss black steel (poverty) wheels
  187. Fastest Rated 15 and 16 inch Tires
  188. help with wheel specs..
  189. Moving up to 15 in...they look to big.Advice
  190. 71 Cutlass Supreme on Corvette Wheels
  191. Anyone know this GM steel rim?
  192. SSI Reproduction and SSI looking wheels.
  193. 1967 Cutlass Supreme 15" or 16" rims
  194. 1965 Cutlass rear wheel size & backspacing
  195. Help!
  196. 15x10 with 5" backspace only?
  197. tires for starfire
  198. 15x8 Wheels
  199. Replace 14 year old perfect tires?
  200. Wheel and tire selection, for 1967 Cutlass Supreme
  201. rim width suggestions
  202. Will these rims fit my 71 442?
  203. Need help with backspacing on 1967 cutlass
  204. 1972 Beauty Rings
  205. need help with tire selection
  206. Recommended alternate replacement rims for1956 Olds
  207. Wheel Size for 1956 88
  208. Slotted mags
  209. 215/70/15
  210. Rims for Oldsmobile Delta 88 1984
  211. Can someone help me decode theyese Rally wheels
  212. In 1969 These Wheels Must Have Been the Real Deal.
  213. Any steel wheel gurus?
  214. 295/50/15's
  215. Wheel Vintiques SS1 Repros - What do you guys think?
  216. wheels for 1959 olds 88
  217. New Tires
  218. I Like My New 5x5 Rim
  219. ss11 center caps nos oem ??
  220. Tire/wheel size question
  221. Radial wide whites tires for cheap
  222. Tony's Two-tire blowout
  223. 79 wheels and tires
  224. New rims
  225. New wheels and tires on my 71
  226. Wheels and tires finally installed
  227. Chrome SSI's - 14x7
  228. rim identify
  229. new tires 255/60 mickey thompsons with spoke hub caps
  230. Got my new wheels on....
  231. Glass Beading and Repainting Wheels
  232. snap on center caps
  233. 1957 rim color
  234. 67 442 steel wheel size and code
  235. 265x50x15 bf goodrich radial ta
  236. Time for new front tires on 68 Cutlass Supreme...
  237. Weird Wheels
  238. Extremely short studs?
  239. 64 Cutlass Max Front Tire width?
  240. 62 Starfire wheel studs and lugs
  241. What is Maximum tire size for my 15" SS II's?
  242. Tire Size: Power V/S Fuel Economy
  243. 15x8 with 4in backspacing
  244. Tell Me About These Rims
  245. Delta 88 '75 wheels
  246. how do i get a rims to fit my stock hub
  247. Safe to weld?
  248. New 14" Plain Wheels - where to buy?
  249. 18x9 on '76 Olds Custom Cruiser?
  250. Need wheel size verification
