Click Here
Aftermarket Wheels for 63 Starfire
Old Oct 25, 2014 | 08:55 AM
Don R.'s Avatar
I'm thinking about adding some period look custom wheels to my Starfire, like Cragar SS's or American Racing 200S. Probably 15" by 7" all the way around, I will reuse the BFG T/A's I currently have but lose the white letters. Is my current bolt pattern 5" by 5 or 4 1/2" by 5? Has anyone else done this, are there any issues with clearance or offset choice?
And my main concern, are the correct exposed nuts available to fit the left hand threads on the left side of the car?
Any help will be appreciated.
Old Oct 25, 2014 | 01:34 PM
Your car's bolt pattern is 5 x 5". You will want wheels with close to zero offset (backspacing is dependent on wheel width, whereas offset is independent of wheel width). And yes, you can get the LH thread lugs anywhere. The wheels you get will dictate the style. Your wheel studs are 1/2-20. Here is the first one that popped up in a Google search:
http://www.summitracing.com/parts/crr-27727-4/overview/
Old Oct 26, 2014 | 09:16 AM
Don R.'s Avatar
Thanks Joe, that helps. Looking at those lugs for the Cragar SS wheels with the multiple size lug slots and washers, does anyone have feedback on that design? I've always loved the original chrome SS style but have never actually owned a set and have heard about issues with the lugs and with corrosion problems. Any comments?
Old Oct 26, 2014 | 02:30 PM
rocketraider's Avatar
Oldsdruid
http://www.radirwheels.com/wheels.htm
If I were going to put a/m wheels on my 64s, Radirs would be my choice. No they're not cheap, but they are the best 60s vibe I know of.
Unless of course you could find some Kelsey Hayes MagStars...
Old Oct 26, 2014 | 10:02 PM
Well, all I can say is that I've never had a set of chrome lug nuts that didn't rust eventually. I've bought cheap, I've bought expensive, and on all of them the chrome starts to crack in the corners and rust starts. I take care not to use an impact wrench, though I have not tried the plastic-lined sockets. This is why GM used lugs with stainless steel outer caps.
Old Oct 27, 2014 | 11:35 AM
Don R.'s Avatar
Very true. My car stays dry most of the time so probably not a major problem...I may look for those plastic lined sockets though, sounds like a good idea.
My question actually was aimed more at the Cragar SS wheels themselves rather than the lug nuts. In the old days I remember they had major problems with the rims rusting and the centers pitting but that was in winter-salty Illinois - anyone have those problems in dry climates?
Old Oct 27, 2014 | 11:44 AM
Don R.'s Avatar
I forgot about the Radirs, they are expensive! But on the list...
I had KH Magstars on my first car, a 55 Ford. Only on the front, with chrome slots on the back - I bought the whole set from a buddy who had them on a Mustang. Liked them so much they moved to my next car, a 64 Galaxie!
nj_cutlass72
Mar 2, 2012 08:03 PM
WTony
Jan 15, 2011 07:53 PM
cig1ar
Jan 10, 2011 05:51 PM
Southern_Hospitality
Mar 22, 2010 06:11 AM
liebster
Apr 2, 2007 09:30 AM
