Click Here
wheel studs
Old May 3, 2015 | 07:18 PM
antweave's Avatar
wheel studs
I know you would disagree with this but I am putting some 20 inch wheels on my 71 cutlass and have some new but longer wheels studs I have a idea of how to install the studs but I knew somebody here would lead me in the right direction please help. How to I line up the knurls or what ever they are callled
Old May 3, 2015 | 07:33 PM
No need to align the knurls. I slip the lug in until the knurled part contacts the back of the hub, thread an acorn lug nut turned backwards (flat side towards hub), then tighten the nut to pull the stud into the hub. Check the backside to make sure the stud pulls flush to the hub.
Old May 4, 2015 | 11:34 AM
rjohnson442's Avatar
Mr. Johnson
Doing that many studs at one time you may want to get a wheel stud installer. Or you can make one if you have a small old bearing laying around.
cuttyroe
Wheels and Tires
Apr 17, 2011 12:06 PM
62HOLIDAY
Dec 8, 2010 05:03 PM
62HOLIDAY
Nov 24, 2010 02:20 PM
darrenrf
May 27, 2010 06:20 PM
The Stickman
Mar 16, 2010 07:34 PM
