Larger wheel studs?
Old March 15th, 2010, 07:44 PM
The Stickman's Avatar
Larger wheel studs?
Ok we are putting new wheels and tires on the wife's car and I noticed how small the wheel studs are. I have heard GM made them larger after 1979 which is what this car is. So could I just drill out the hub and drum on the rear and the brake rotor/hub on the front and put new larger ones in?
The Stickman is offline
Old March 15th, 2010, 09:53 PM
car guy
gearheads78's Avatar
they went to 12mm studs in 1982. I am not sure if the knurl was the same of not.
gearheads78 is offline
Old March 16th, 2010, 08:34 AM
I'm not sure where you want to go with wheel studs. The 1/2-20 studs used on the earlier cars are nearly 13mm, so that's a small upgrade. You can also get 5/8" diameter racing studs, which require machining to install.
The bigger question is, why do you think you need them? A 1/2-20 grade 8 wheel stud has a shear allowable of 14,560 lbs. In the 5 x 5" bolt circle, the five wheel studs can carry over 15,000 ft-lbs of torque per wheel. Can your tires put this to the ground without spinning?
joe_padavano is offline
Old March 16th, 2010, 11:58 AM
Well the reason I thought it might be a problem is I took off the current Cragar wheels and went to put on a regular wheel and was going to use regular lugnuts and they slid stright over the studs. You could put the nut over the stud and not have them touch each other. I thought that a bit small.
Old March 16th, 2010, 01:31 PM
car guy
Your wifes car uses 7/16 studs. All cars with 5 on 4.75 did until the change in 1982 metric 12mm studs were used.
Old March 16th, 2010, 06:53 PM
DOH! I was thinking of Stick's Custom Cruiser, not the Cutlass Cruiser.
Old March 16th, 2010, 07:34 PM
I decided just to use the 7/16th ones. They are small but we don't plan on huge hp for her car anyway. Not yet anyway. Now mine I do have secret plans for.
Ctott70
July 17th, 2022 05:16 AM
AzChevs
November 8th, 2013 10:33 AM
dfire25
July 10th, 2013 09:37 PM
brokeandugly21
Ninety-Eight
April 23rd, 2011 01:24 PM
Mike Hathaway
March 23rd, 2005 08:12 PM
Quick Reply: Larger wheel studs?
