Click Here
wheel studs
Old May 3rd, 2015, 07:18 PM
antweave's Avatar
wheel studs
I know you would disagree with this but I am putting some 20 inch wheels on my 71 cutlass and have some new but longer wheels studs I have a idea of how to install the studs but I knew somebody here would lead me in the right direction please help. How to I line up the knurls or what ever they are callled
antweave is offline
Old May 3rd, 2015, 07:33 PM
No need to align the knurls. I slip the lug in until the knurled part contacts the back of the hub, thread an acorn lug nut turned backwards (flat side towards hub), then tighten the nut to pull the stud into the hub. Check the backside to make sure the stud pulls flush to the hub.
Fun71 is offline
Old May 4th, 2015, 11:34 AM
Mr. Johnson
rjohnson442's Avatar
Doing that many studs at one time you may want to get a wheel stud installer. Or you can make one if you have a small old bearing laying around.
rjohnson442 is offline
cuttyroe
Wheels and Tires
April 17th, 2011 12:06 PM
62HOLIDAY
December 8th, 2010 05:03 PM
62HOLIDAY
November 24th, 2010 02:20 PM
darrenrf
May 27th, 2010 06:20 PM
The Stickman
March 16th, 2010 07:34 PM
Quick Reply: wheel studs
